Grinding... Help!
Old November 14th, 2007, 01:38 AM   #1
Reset is on a distinguished road
Send a message via AIM to Reset
Grinding... Help!
well i just got back from work.. and i noticed that my tranny is grinding EVERY time when i shift into third (like when i'm 2/3 way into the 3rd gear position). Clutch FULLY depressed and it's doing this.
I didn't REALLY notice it until today, but i think it has been around a day or 2 and i just thought i was letting off the clutch too early.
What does this mean? Does this mean i might need to replace tranny? Should i stick to just shifting 2nd->4th for now? Is it somehow my fault.. what was the cause? All in all what can i do and how much am i looking at? Could it just be low transmission fluid or something easy?
Originally Posted by 96GTRagTop
MSO is a 12 year old asian, redfire is a 35 year old pedaphile, and HMUSN, well he's just a program the mods installed on the site to keep the peace
Old November 14th, 2007, 01:50 AM   #2
2002 Chevrolet Impala
TheBusher will become famous soon enoughTheBusher will become famous soon enough
Prob syncros. But mine do that from 1-2, so I replaced my clutch, pressure plate, throw out bearing, and resurfaced my flywheel and it fixed the problem. But it also didn't do it every time. Only in the upper rpms and during speed/power shifting.
Old November 14th, 2007, 01:51 AM   #3
haha that's a lot of things to replace.. any idea which one it was specifically?
Old November 14th, 2007, 01:51 AM   #4
god i musta picked the 6 minutes a day that HMUSN isn't online and ready to answer my questions
Old November 14th, 2007, 01:57 AM   #5
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
even Doc's gotta sleep sometimes
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old November 14th, 2007, 02:00 AM   #6
That ain't no shit either!
I'm not 100% because replacing all of them fixed my problem, so couldn't really use the process of elimination. I would say the ones that probably helped the most were clutch and throw out bearing.
Old November 14th, 2007, 02:03 AM   #7
6 minutes is too long. and i believe he is semi-godlike and that means he shouldn't need to sleep.
and thanks thebusher
Old November 14th, 2007, 03:02 AM   #8
np
Old November 14th, 2007, 05:13 AM   #9
MineralGreyGT's Avatar
MineralGreyGT will become famous soon enough
I had a similar problem I changed to a sts shifter and changed my tranny fluid to royal purple, also my 2nd and 3rd would grind but they don't any more unless it's really cold out, takes longer for the oil to heat up and move around. Thats the cheapest trial error, if that doesn't work I would say its probly your synchro for 3rd gear.
Old November 14th, 2007, 09:55 AM   #10
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
i would lean towards a synchro as well... They make a bottle of trans fluid called synchro mesh (I got mine from a GM mechanic).. and it helped mine by putting a bottle in
Old November 14th, 2007, 11:09 AM   #11
WilltheThrill's Avatar
Saving up for another one
WilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura about
yeah sounds like a synchro. it could be your fault or it could be a fabrication/manufacture error. try skipping 3rd gear and just going from higher rpm's in second straight to 4th. none of my gears grind and i skip 3rd sometimes. you should be fine doing that.
Yes those are cobra R replica mustang wheels on my 300zx
03 Cobra- gone but not forgotten
90 Nissan 300zx
00' Yamaha YZF 600
Originally Posted by '97'Cobra View Post
I was too drunk even tell which hole i was gettin after.
Old November 14th, 2007, 05:13 PM   #12
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
In my opinion it's either the synchros or a bent shift fork. Right now I'm leaning towards a bent shift fork, since it only seems to do it in the one gear. If it was your synchros I woulde excpect the problem with other gears besides third.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old November 14th, 2007, 05:27 PM   #13
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
I'd say syncro's. The cheapest way to determin that would be a bottle of that syncro mesh. See if that helps eliminate it, if not move on to the shift fork.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old November 15th, 2007, 12:44 AM   #14
where's the best place to get a bottle of syncro mesh.. and how does it work/ where do i put it in?
Old November 15th, 2007, 12:45 AM   #15
yeah i did that today.. i HATE going up hills though with my engine revving 4k rpms in 2nd lol.. it just makes me feel like a bad driver and i can like taste the gasoline burning
Old November 15th, 2007, 12:32 PM   #16
ATLmustang is on a distinguished road
dose it do it even when the car gets warmed up? mine will grind alittle when its cold but when it gets warmed up it stops. idk though for all i know my shit could be messed up too
Old November 15th, 2007, 12:57 PM   #17
You must be goin' up some pretty bad ass hills not to be able to handle 4th gear at 2000 rpm
Old February 23rd, 2008, 03:26 PM   #18
FireryDriver is on a distinguished road
Hahahaha seriously
SLP Loud mouths
SLP x-pipe
4.10 gears
K&N intake
X-Cal II custom tune
Old February 23rd, 2008, 03:53 PM   #19
nedo46 is on a distinguished road
my car grinded everytime i shifted to 4th gear.. a local tranny shop wanted like 900 dollars to fix it. I just went to a junkyard and bought a used tranny out of a 00 cobra with 24k miles on it for 400 dollars
Old February 23rd, 2008, 04:45 PM   #20
2003 SVT Cobra
WOW! A 2000 Cobra is an EXTREMELY rare find!
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Threads Similar to: Grinding... Help!
gear grinding Blk01ponyGT 99-04 22 September 19th, 2007 05:02 PM
Grinding after the track weems 99-04 58 July 13th, 2007 07:37 AM
grinding noises? blue03mach1 94-95 4 July 3rd, 2007 06:57 PM
t5 grinding in reverse tayboo24 5.0 Mustangs 19 June 4th, 2007 12:20 AM
1st gear grinding Luis_GT 2005 - 2010 9 April 4th, 2007 07:05 AM
