Question about cams.
Old August 22nd, 2006, 06:52 AM   #1
White2000GT is on a distinguished road
How necessary is a tune when more aggressive cams are installed? The reason I ask is because I have access to a shop with a certified mechanic who could assist me with the labor, but there is no dyno at the shop or any other type of tuning equipment or know how. I have less than six months left here before I transfer back to the States, so part of me wants to just wait until then to get it done, but that other nagging part of me is way too anxious about getting it done NOW NOW NOW!
Any thoughts?
2000 Mustang GT 5 speed
BBK LT headers
BBK O/R X pipe
Magnaflow Magnapack catback
UPR CAI
Old August 22nd, 2006, 07:32 AM   #2
Drgnracin72's Avatar
a must. your going to be drawing in more air and suff and that needs to be corrected with the tune. but anytime you do anything internally, a retune is a must. if you dont go to a big cam, you could probably maybe run without a retune but you wont be able to get near the performance that you could possibly
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old August 22nd, 2006, 08:38 AM   #3
Good point. I guess I will just have to be patient then. Being patient sucks.
BBK LT headers
BBK O/R X pipe
UPR CAI
Old August 24th, 2006, 01:33 PM   #4
MikeyS281's Avatar
1999 Mustang GT
14.2 no mods, bald tires
MikeyS281 is on a distinguished road
Re: Question about cams.
Any thoughts?
Another thing that you need to watch out for is your valves and the tops of your pistons. If you go with a big cam then you have to get new cam gears for the timing to be right. You don't want to mess up your internals for a time consuming and expensive rebuild because you were to anxious to get it done and go play. One of my buddies did a head and cam swap and he had to get the new cam gears cause the valves were touching the pistons. When you install your cams make sure to check clearances before start-up.
Old August 24th, 2006, 07:01 PM   #5
yeah its def a good idea to check your ;piston to valve clearence
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: Question about cams.
Cams question? Cantbeatblack 99-04 27 October 2nd, 2007 06:44 PM
Installing Cams question??? Cantbeatblack 99-04 9 July 22nd, 2007 01:59 PM
Installing Cams question??? Cantbeatblack 99-04 4 July 21st, 2007 01:24 AM
got a question about cams sean1017 99-04 6 May 10th, 2007 12:58 AM
Question Regarding Cams Bigb2000GT 99-04 3 March 26th, 2007 06:13 AM
