unstoppable @ speed of light
Major engine problems, please help!
I just drove back to work from lunch and my engine started detonating really bad. Almost like I was in too high of a gear or something, except I was in second and it was sounding horrible. I turned into the parking lot at work and my car just died! I tried to restart it and it just kept turning over and didn't sound like it waf firing at all. It sounded like it may have gotten WAY out of time. Anybody know what it might be?
I figured it out. It is overheating. Strange though, I let it idle and refilled the radiator and it never overheated until I started driving down the road. When it got too hot again I pulled over and opened the cap and the coolant level was low but before I could get more water in it it rose back up to full again. I turned the heater on full blast and drove the rest of the way to work and didn't have even the slighest hiccup from the temp. gauge
11.21@123 -150 shot
![]() iTrader: 1 reviews
You may have air in the system. Our cars are famous for this. You can't get the system full just utilizing the overflow. There is a vent at the top of the system. You have to remove the shaker to get to it. Remove the filler plug with a 1/4 drive and fill from there. Start the car and let it circulate. Add as needed. Let us know how it goes.
Thanks. The way it's overheating is strange. It will stay in the mid temp. range and do just fine for around 4-5 miles and all of a sudden the needle will skyrocket towards the red zone. If i turn it off and releive some pressure from the cap and restart it it runs fine for a while again. and never overheats at idle. It's making me crazy
Anybody know/have any good advice on changing the thermostat and spark plugs? I ordered new cooler plugs that will be here friday.
I had a similar problem with my '98 GT. It was a copper tube that was inside a sleeve that had cracked and at high rpm's it would spurt out. Check all your hoses and lines that carry coolant to make sure theres no leak.
2001 YUGO GT
Go simple first, check hoses, circulation, and first thing I would replace is the thermonstat, change it to a 160 degree, this is really true if the orginal is still in the motor. And yea ya can check them but it its out , so just change it. Also check to endsure your fans are coming on, if not than back trouble the fans ans control. Like say start out easy and than ease on back. W.P.
Threads Similar to: Major engine problems, please help!
| !!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!! | Hububula | 5.0 Mustangs | 15 | May 28th, 2008 10:00 AM |
| !!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!! | Hububula | 5.0 Mustangs | 3 | June 6th, 2007 10:30 PM |
| MAJOR TRANNY PROBLEMS! | Jeff99gt | 99-04 | 13 | May 9th, 2007 01:37 PM |
| Hydroboost Major Problems, Ehhh?? | Invictus | 99-04 | 8 | February 20th, 2007 05:01 PM |
| Major Problems, Need Help | super240sx | 99-04 | 10 | October 30th, 2006 05:48 PM |
