H/E Single vs. Dual
Old November 16th, 2007, 12:48 AM   #1
DocB is on a distinguished road
H/E Single vs. Dual
Hey guys, I need some advice. I'm about to order a little bigger H/E and have the option of a single or dual pass unit.
I understand the difference in the flow design, but am wondering if the dual will cool better? Is there any hard data to substantiate this?
(I did a search, but couldn't find anything on this).
Old November 16th, 2007, 01:09 AM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
H/E = heat exchanger? = intercooler?
Old November 16th, 2007, 01:11 AM   #3
Yes, intercooler radiator for SC.
03 Cobra RAI, 2.80 Pulley, Idler Kit, Accufab TB & Ported Plenum, Kooks LTs & Hi Flow Cats, Magnaflow CB, CenterForce Stage II Clutch, Billet Aluminum FW, Hi Flow FP, Urethane Bushings, QA1 Adj. Rear Shocks, Shock Tower Brace, Sub Frame Connectors, 6 Pt. Roll Cage, FR500 18x9, Falken 452 255-285/35/18, FR Drilled/Slotted Rotors, Red Cobra Calipers, SCT X Cal Custom Tuned
Old November 16th, 2007, 10:23 AM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
You might want to post this in the poweradder forums too.
360HP / 345TQ N/A
Old November 16th, 2007, 10:33 PM   #5
Thanks, I'll try it over there.
It just seems odd to me that many (quite a few) aftermarket H/Es have been installed but no one seems to know why they are installing one type over the other.
I mean, if I'm going to install a replacement part on my car, I want to know why one product is better/different than another. We all do it with other items (e.g. blowers), how come not the intercooler?
Just wondering.
Old November 17th, 2007, 02:45 AM   #6
2000 GT
dual core will cool better... it does with radiators anyways. I have a different blower than you so no idea. Mine is water based, and used the one kb gave me (works great)!
Old November 18th, 2007, 01:38 AM   #7
Thanks Everyone, I think I'll be going with a single. It's a tough decision. The Dual seems more popular, is it only because of the marketing hype from AFCO when they first cameout with them? Don't know.
So far, no one could tell me why the dual is better FOR OUR APPLICATION.
The following pertains only to installation of an aftermarket H/E (intercooler) for the SC on an 03-04 Cobra.
My research so far has lead me to believe that for our application a single pass H/E would be the best and most practical for these reasons:
1. Same (or very little, if any) difference in efficiency. This is due to the size of radiator, # of tubes, # of fins per inch, and depth of radiator. Stratification will not occur.
2. Retain the hard crossover tube, instead of replacing with another soft hose.
3. An additional bend to the inlet with dual.
4. Difficult (maybe impossible) to install brake cooling ducts later with dual due to hose routing.
5. Will the higher resistance to flow in a dual affect the pump?
6. Turbulence due to increased velocity going through the dual-good or bad? for actual heat exchange? (Delta T of coolant).
If you have anything to add- pro or con - I'm all ears.
TIA.
Threads Similar to: H/E Single vs. Dual
Dual Single DIN to Single Double DIN Console Conversion? lil666 99-04 5 October 13th, 2010 07:08 PM
Single Ladies Hourofpain The Clubhouse 135 November 27th, 2007 12:28 PM
Stock Single to DUAL Exhaust trueballerisme V6 Mustangs 41 January 5th, 2007 05:00 AM
Single or Dual... JBake V6 Mustangs 10 November 1st, 2006 03:23 AM
Single or Dual Exhaust servdog V6 Mustangs 24 October 25th, 2006 11:45 PM
