2003 Ford Mach
Traveling at the speed of a photon
Aluminum D/S (driveshaft)
so i understand that these D/S need zero balance. therefore making it an easy bolt on. right? But is the setup different than on a manual? what should i purchase besides the d/s to make this install easy and effective on my automatic? gt and mach share the same driveshaft right?
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
2003 Ford Mach
48.47@ 12.58
just buy the drive shaft for a manual and use your automatics yolk.
it's a good mod and a direct bolt on.
2003 Ford Mach
once again to the rescue...thnx
yeah but you may still want to have it checked for balance. cuz if its out just a little bit, it can cause a whole lotta problems
2003 Ford Mach
so i should just get a driveshaft loop while im at it? i guess off to the shop for this one then..
48.47@ 12.58
yea why not.
a D/S loop is always a good thing
whats a driveshaft loop?
It's a piece of steel in a U shape which typically bolts to the under carriage of the car, and surrounds the drive shaft. In the event of a U joint failure, the loop keeps the drive shaft from going completely haywire and possible causing you to lose control.
ahh i see thanks man
Anytime Steve O
2003 Ford Mach
also can keep you from being a human in a stang catapult.
so is drilling required for the loop?
ahh i have seen that i just didnt know thats what its called in english lol
lol@chris1
I hear ya Steve
The Mean Green
The saftey loop with add a little more stiffness to the chassis as well.
#18 | |
2003 Sonic Blue Mustang GT Steeda cold air intake Bassani off-road x-pipe Magnapacks Steeda Tri-Ax Shifter |
Threads Similar to: Aluminum D/S (driveshaft)
| aluminum driveshaft | 03TropicGt | 99-04 | 27 | November 4th, 2007 01:16 AM |
| ALuminum Driveshaft | USARMY1983 | 5.0 Mustangs | 0 | April 13th, 2007 11:51 AM |
| aluminum driveshaft | stepfaster2000 | General Tech | 9 | April 4th, 2007 06:34 PM |
| aluminum driveshaft | 97TunedMustang | V6 Mustangs | 0 | June 21st, 2006 01:14 AM |
| aluminum driveshaft | kbstang | 99-04 | 7 | March 19th, 2006 01:44 AM |
