Romeo or Windsor Heads
Old November 17th, 2007, 06:34 AM   #1
jrfan4life's Avatar
2001 Mustang GT
NA
jrfan4life is on a distinguished road
I want to look for a set of stock PI heads that I can get ported, polished and drop a nice set of cams in, But how do I know if I have Romeo or Windsor heads in my car now? I want to make sure I get the right ones... Then I just need to talk my wife into it....hmmmmmmmm I am thinking comp stage 2 cams..
Old November 17th, 2007, 09:54 AM   #2
mdvaldosta's Avatar
11.47@120.58
Romeo heads have 11 valve cover bolts, Windsor heads have 13. Count em.
Old November 17th, 2007, 10:33 AM   #3
mjkids's Avatar
mjkids is on a distinguished road
i think after 99 one side is 11 and the other side is 13. i will check i just bought bbk valve cover and i think thats what they said. i think
2000 ford mustang gt convertible
2004 ford lightning truck,,,,,sold
2001 ford mustang/cobra,,,,sold
2008 ford f-350 4x4 truck
1989 ford notch back 5.0
2006 custom build bobber
Old November 17th, 2007, 10:38 AM   #4
mjkids's Avatar
Old November 17th, 2007, 11:40 AM   #5
2000 Mustang Gt
13.56 @ 106
2000stangGT is on a distinguished road
what years your car?
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams
Manley Valves/Springs - Centerforce Dual Friction
BBK LT's - BBK o/r H - Bassani catback
FRPP 4.10s - XCAL2 - BBK UDP's
306rwhp/333rwtq
Old November 17th, 2007, 05:37 PM   #6
jrfan4life's Avatar
2001 Mustang GT
NA
2001 Gt.....
Old November 17th, 2007, 05:39 PM   #7
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
its a romeo...
96-98= romeo
99-00= windsor
01-04= romeo
Old November 17th, 2007, 05:44 PM   #8
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
actually an 01 is where they changed. some early ones had the windsor
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old November 17th, 2007, 05:46 PM   #9
2002 Chevrolet Impala
TheBusher will become famous soon enoughTheBusher will become famous soon enough
Is there i dif performance wise???
Old November 17th, 2007, 05:57 PM   #10
Proud American
MustangMatt96GT's Avatar
windsor are known to blow out the spark plugs. Both work just fine. And if you are getting them worked over, they should correct the spark plug issue anyway. It doesnt matter if you use windsor or romeo heads. they are interchangeable. 11= Romeo and 13/14= windsor. My romeo motor is getting windsor heads put on later this winter.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old November 17th, 2007, 06:16 PM   #11
limited's Avatar
the only real difference,besides how many valve cover bolts ,are the windsor has individual cam caps and the romeo has girdles,I prefer the windsors,because they are so much easier to change the springs(on the car). don't know if one system is better than the other thou
Threads Similar to: Romeo or Windsor Heads
romeo heads on windsor block 2kGT 99-04 16 November 1st, 2007 06:51 PM
Difference between windsor and romeo heads suds488 96-98 0 October 30th, 2007 06:29 PM
which one to have Romeo or Windsor shamntgmry 99-04 75 October 18th, 2007 10:33 AM
romeo or windsor energiesource 99-04 1 September 29th, 2007 02:59 PM
romeo or windsor TrueBlueGT01 99-04 5 December 10th, 2006 02:26 PM
