Fuel Pump Question
has anyone heard of useing a ford focus stv fuel pump on a supercharged mustang
yup.
It's common.
is it just the plan old focus pump off of any stv
yup.
thanks
yup. lol
2000 GT
Do you know how much the ford GT pump flows? Thats the one on my car... if its not installed right it wont run correct? Because it runs great and idles fine but under load and throttle it bogs down. Although i did up the boost by 8lbs and its missing on #3 so going to fix that... and install my ignition bas.
not sure how much it flows. probably in the 255lph range or higher.
if it's not installed correctly it won't run. I don't think the pump is your problem though
Thats what I run with my Procharger. And it is rated 300lph
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the focus pump is only rated at 255lph. the aviator is rated 370lph.
11.47@120.58
Focus Pump On Blown Mustangs FTW
Focus pump is good deep into the 400 rwhp range with a BAP (Boost a Pump). I ran low 400's for 2 years with a Focus pump and no BAP.
2000 GT
So its probably spark blow out/needs a tune? I knew it would be i thought it wouldnt be this bad!
The Focus SVT pump is rated at 255 lph and sells for $135 at the dealer. I believe the stock GT pump is rated at 110 lph. I installed the Focus pump for my P1SC install.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
6.82@100mph 1.45 60'
if you want to be in the 600 rwhp range.... what pump should you get?
2000 GT
Smartest way would get a cobra tank and put 2 focus pumps in it. What i did is a ford GT pump with a BAP.
I don't have any experience in that area, but Aeromotive Fuel Systems have some serious HP pumps reasonably priced.
Threads Similar to: Fuel Pump Question
| fuel pump question | sixpack | 5.0 Mustangs | 4 | November 8th, 2007 06:54 PM |
| Fuel Pump Question | J Mac0123 | 99-04 | 5 | August 24th, 2007 06:26 PM |
| Fuel pump istall question | jam77 | 5.0 Mustangs | 4 | July 21st, 2007 02:03 AM |
| fuel pump and pressure question | haloallstar | Modular Mustangs | 5 | February 22nd, 2007 09:49 PM |
| Fuel Pump Question | bigbadtalontsi | 5.0 Mustangs | 1 | January 24th, 2007 07:53 PM |
