Fuel Injectors...
I recently upgraded to from a 98 GT to an 04 GT and the car seems to be guzzling gas more my 98 with 4.10 gears. How can I tell what size injectors are in my car?
11.47@120.58
Stock is 19#, injector size doesn't really make a difference though as the car is only gonna use as much as it needs. They're usually id'd by color:
Yellow: 19lb Injectors Blue: 24lb Injectors Red: 30lb Injectors Green: 42lb Injectors Are the most common ones. |
Proud American
Lime Green: 36lb injector
Okay, well the injectors that i have look pink, what are they?
These lime green ones are 42 pounders
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
48.47@ 12.58
21 pounders.
11.47@120.58
I've heard of folks claim Ford switched to 21 lb pink injectors on Mustangs near the end of 2002 and on many 2003 - 2004 Mustangs as well. They're (by the numbers) supposably 21.5 lb and it's rumored to be because of the increased in size (85mm) mass air meter. I don't think they're 21's personally, Ford normally rates their injectors at 39psi (I think) which is less than the industry standard (maybe 41 or 42psi) so they're a discrepancy as to what they'd flow with more pressure and I think that's how those pink injectors were rated. Maybe they were outsourced from a different company (not Bosche). I dunno just speculating.
48.47@ 12.58
^ that's exactly what I heard.
my 2001 was stuck with the poor little 19's. till I dropped 39's in
My '04 GT is a virgin at 15,000 miles and came equipped with the pink ones.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. Last edited by gsjohnson; November 17th, 2007 at 09:31 PM. |
11.47@120.58
48.47@ 12.58
did you have to buy the pig tail harnesses too? splicing those in were a pita
11.47@120.58
Dunno, Modular Powerhouse did it (was up there getting tuned and needed them).
bringing this old thread back to life i have some brand new pink ones that i want to put in my stock 88 roller motor.i have a 93 upper and lower cobra intakes with mass meters and such any problems with idle ?
Threads Similar to: Fuel Injectors...
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| Fuel injectors | ByPopularDemand | V6 Mustangs | 10 | June 23rd, 2007 10:09 PM |
| Fuel Injectors | Euroeater95 | 94-95 | 5 | June 21st, 2007 11:02 AM |
| Fuel injectors | Chasinsparks | 99-04 | 3 | April 7th, 2007 11:55 AM |
| New Fuel Injectors | 1998_svt_cobra | 96-98 | 22 | February 19th, 2007 09:24 AM |
