Mach 1 Hood Question
Old November 20th, 2007, 09:33 PM   #1
energiesource's Avatar
energiesource is on a distinguished road
So this would probably look stupid but ill ask anyway. With a mach 1 hood, would it fit over top of a kb 2.6 supercharger? because it says you need the cobra r hood or some type of cowl but if this would work i think it'd be alot better.
Old November 20th, 2007, 09:42 PM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I'm just guessing here but I'll say no. There's not much clearance between the shaker and the hood. If you can, then I am glad I am wrong.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old November 20th, 2007, 09:44 PM   #3
no i mean like...no shaker
almost like the supercharger replaces the shaker. if that makes sense.
Old November 20th, 2007, 10:52 PM   #4
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
Most likely. Look up the external dimensions of a KB supercharger and I'll measure the extra heigth provided by the hump in the Mach hood. Then you've got your answer.
I also know they make a KB for a Mach and the stock hood and shaker are still there and functional. So it seems like the s/c would fit under the shaker completely.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old November 21st, 2007, 12:35 AM   #5
2001 mustang GT
12.67@110.34
kennyGT is on a distinguished road
Send a message via AIM to kennyGT
possibly not as big as the 2.6 tho
88 LX automatic-non stroked 302 with iron heads
01 GT manual-h-pipe bullets dumped-125shot
97 GT automatic-SOLD
Old November 21st, 2007, 04:56 AM   #6
03 R Code's Avatar
I don't see why not. The external diameters can't be that much larger than any other model.
Threads Similar to: Mach 1 Hood Question
Mach II Ram Air Hood + Invader Shogun front Rohis Visual 23 August 13th, 2007 11:47 AM
Mach 1 hood swap csyharper 99-04 2 February 28th, 2007 03:49 AM
Mustang Mach II Ram Air Hood Bies08 Visual 43 February 23rd, 2007 01:31 AM
Mach 1 Hood SVTCOBRA 99-04 12 January 21st, 2007 05:12 AM
Cobra R Hood or Mach 1 or 2 Hood? Pick 1 of 4 hoods. Chris02 99-04 16 November 1st, 2006 08:46 AM
