Casper... My Truck
casper...any TBS OR QUITE RECALL ON MY '03 SUPERCREW
Give me the VIN and i will give you all the secret info you need! haha
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
1FTRW07633K861046
it says its a bad VIN ??
I'll have to check it when it's daylight..
thanks! |
1FTR07633KB61046
Wow, daylight came quick! lol.... youre out of control. I can tell this one wont work either cause its not 17 digits long! hahaha
1FTRW07633KB61046
OASIS RESULT:
1FTRW07633KB61046 See bottom of the OASIS result for contact ID 09/30/2005 22:20:17 © Copyright 2002-3 Ford Motor Company. All rights reserved. VEHICLE INFORMATION VEHICLE DESCRIPTION 2003 F-SERIES LD BODY STYLE F-150 CREW FLARE SIDE 4X2 ENGINE 4.6L SOHC (WINDSOR) TRANSMISSION 4R70W 4 SPD AUTO AXLE CODE H9 ENGINE CALIBRATION 3F516M0A GENERAL WARRANTY INFORMATION WARRANTY START DATE 05/28/2003 BUILD DATE 12/02/2002 SALE MILEAGE ARN MESSAGES ATTENTION TECHNICIANS AND SERVICE MANAGERS: BEFORE ADDRESSING AXLE NOISE (WHINE/HOWL), SEE TSB 05-12-06 BEFORE REPLACING SEAT BELT RETRACTOR (-611B08/9, 611B68/9-) SEE TSB 05-16-11 WARNING MESSAGES LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE OUTSTANDING FIELD SERVICE ACTIONS NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES 0711 - USA 2002 NEW 60/60,000 PREMIUMCARE W/ROADSIDE ASSIST. STANDARD DEDUCTIBLE: 50 USD OWNER NAME: PAMELA CRANER OPTIONS: EXPIRATION DATE: 05/28/2008 DISTANCE: 60,000 RENTAL: 28 UP TO 10 DAYS TOWING: 0 USD CONTRACT SOLD BY: USA 08799 ESP CONTRACT START DATE: 05/28/2003 THE ROAD HAZARD TIRE COVERAGE BENEFIT EXTENDED TO ELIGIBLE FORD MOTOR COMPANY VEHICLES IS ONLY IN EFFECT DURING THE TERM OF THE NEW VEHICLE LIMITED WARRANTY. REPAIR HISTORY NO REPAIR HISTORY ON VEHICLE Click Here for Full Warranty History END OF OASIS REPORT FOR 1FTRW07633KB61046
hey thanks...the rear howls on this truck
Its funny you say that. I just did rear ends on a 02 Navi, and a 03 F-150 for rear howls. There is TSb's about this . I will insert which ones are avalible. Then you can go to youre dealership and use youre warranty!
OASIS RESULT: 1FTRW07633KB61046 See bottom of the OASIS result for contact ID 10/02/2005 14:30:42 © Copyright 2002-3 Ford Motor Company. All rights reserved. VEHICLE INFORMATION VEHICLE DESCRIPTION 2003 F-SERIES LD BODY STYLE F-150 CREW FLARE SIDE 4X2 ENGINE 4.6L SOHC (WINDSOR) TRANSMISSION 4R70W 4 SPD AUTO AXLE CODE H9 ENGINE CALIBRATION 3F516M0A GENERAL WARRANTY INFORMATION WARRANTY START DATE 05/28/2003 BUILD DATE 12/02/2002 SALE MILEAGE ARN MESSAGES ATTENTION TECHNICIANS AND SERVICE MANAGERS: BEFORE ADDRESSING AXLE NOISE (WHINE/HOWL), SEE TSB 05-12-06 BEFORE REPLACING SEAT BELT RETRACTOR (-611B08/9, 611B68/9-) SEE TSB 05-16-11 WARNING MESSAGES LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE OUTSTANDING FIELD SERVICE ACTIONS NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES 0711 - USA 2002 NEW 60/60,000 PREMIUMCARE W/ROADSIDE ASSIST. STANDARD DEDUCTIBLE: 50 USD OWNER NAME: PAMELA CRANER OPTIONS: EXPIRATION DATE: 05/28/2008 DISTANCE: 60,000 RENTAL: 28 UP TO 10 DAYS TOWING: 0 USD CONTRACT SOLD BY: USA 08799 ESP CONTRACT START DATE: 05/28/2003 THE ROAD HAZARD TIRE COVERAGE BENEFIT EXTENDED TO ELIGIBLE FORD MOTOR COMPANY VEHICLES IS ONLY IN EFFECT DURING THE TERM OF THE NEW VEHICLE LIMITED WARRANTY. REPAIR HISTORY NO REPAIR HISTORY ON VEHICLE Click Here for Full Warranty History SYMPTOM CODE INFORMATION 509000 - DRIVELINE AXLE CONCERNS SPECIAL SERVICE MESSAGES 18748 MULTIPLE VEHICLES - USE XY-75W140-QL AND XL-3 INSTEAD OF FEHP AXLE LUBE XY- 75W90-QFEHP AND FEHP FRICTION MODIFIER XL-7 EFFECTIVE IMMEDIATELY, DISCONTINUE THE USE OF FEHP AXLE LUBE, XY-75W90-QFEHP, AND FEHP FRICTION MODIFIER XL-7 IN ALL EXISTING APPLICATIONS. THEY ARE SUPERSEDED BY XY-75W140-QL AND XL-3 RESPECTIVELY. WHEN REPLACING AXLE LUBRICANT IN VEHICLES THAT PREVIOUSLY REQUIRED FEHP, ENSURE THAT THE FLUID IS REPLACED WITH 75W-140 HIGH PERFORMANCE SYNTHETIC REAR AXLE LUBRICANT AND THAT THE "FEHP" METAL TAG IS REPLACED WITH A NEW "75W-140" TAG (F3TZ-4121-AA). IN ADDITION, REMOVE OR BLOCK OUT THE FEHP REFERENCE ON THE MULTI-COLORED LABEL LOCATED ON THE RIGHT SIDE AXLE TUBE. DEALERS WILL BE ALLOWED TO CLAIM UNUSED STOCK OF FEHP AXLE LUBE AND FEHP (XL-7) FRICTION MODIFIER. THE DETAILS OF THE CLAIMING PROCESS WILL BE SUBJECT OF A FUTURE COMMUNICATION. PREVIOUS COMMUNICATIONS ABOUT THIS ISSUE INCLUDE TSB 04-24-20, 05-12-06 AND SSM 18663. EFFECTIVE DATE: 07/27/2005 -------------------------------------------------------------------------------- 18510 1997-2005 MULTIPLE VEHICLES - LENGTH OF DIFFERENTIAL BEARING CAP BOLTS IN TSB 05-6-18 REAR AXLE SERVICE KITS THE 8.8 AND 9.75 AXLE WHINE/HOWL SERVICE KITS THAT WERE RELEASED WITH TSB 05-6-18 MAY CONTAIN DIFFERENTIAL CAP BOLTS (PART NUMBER 46108-S) THAT ARE TOO LONG FOR SOME VEHICLES. THE BEARING CAP THICKNESS VARIES BETWEEN MODEL YEARS, RESULTING IN THE NEED FOR DIFFERENT LENGTH DIFFERENTIAL BEARING CAP BOLTS. TO ELIMINATE ANY CONFUSION ON THE CORRECT BOLT LENGTH, THESE BOLTS WILL BE REMOVED FROM ALL 8.8 AND 9.75 REAR AXLE SERVICE KITS IN THE FUTURE. THE BOLTS INCLUDED IN THESE KITS MAY BE DISCARDED AND THE REPAIR COMPLETED BY RE-INSTALLING THE ORIGINAL DIFFERENTIAL CAP BOLTS. EFFECTIVE DATE: 03/29/2005 -------------------------------------------------------------------------------- 17372 2001-2004 HERITAGE F-150 4X2 WITH 8.8 INCH REAR AXLE - WHINE/HOWL NOISE FROM REAR AXLE SOME 2001-2003 F-150 AND 2004 HERITAGE F-150 4X2 VEHICLES WITH AN 8.8 INCH REAR AXLE, AUTOMATIC TRANSMISSION, AND 139 INCH WHEELBASE MAY EXHIBIT A HOWL OR WHINE NOISE FROM THE REAR AXLE DURING TIP-IN OR CRUISE BETWEEN SPEEDS OF 40 TO 60 MPH (65-100 KM/H). VERIFY THAT THE GEARSET TOOTH CONTACT PATTERN IS CORRECT AND THAT PINION DEPTH AND BACKLASH HAVE BEEN SET CORRECTLY PER WORKSHOP MANUAL SECTION 205-02A. NOTE: BACKLASH SHOULD BE CHECKED IN A MINIMUM OF 6 PLACES AROUND THE RING GEAR. IF ALL SERVICE CHECKS HAVE BEEN MADE AND AXLE NOISE IS STILL UNACCEPTABLE, INSTALL DRIVESHAFT 4L3Z-4602-AAB. THIS REVISED DRIVESHAFT IS DESIGNED TO REDUCE THE LEVEL OF NOISE PRODUCED BY THE REAR AXLE. EFFECTIVE DATE: 12/01/2003 -------------------------------------------------------------------------------- 17064 2002-2003 F-150 4X2 - WHINE/HOWL FROM REAR AXLE SOME 2002-2003 F-150 4X2 VEHICLES WITH A 9.75 REAR AXLE AND 139 INCH WHEEL BASE MAY EXHIBIT A HOWL OR WHINE NOISE FROM THE REAR AXLE DURING TIP-IN OR CRUISE BETWEEN SPEEDS OF 40 TO 60 MPH (65-100 KM/H). VERIFY THAT THE GEARSET TOOTH CONTACT PATTERN IS CORRECT AND THAT PINION DEPTH AND BACKLASH HAVE BEEN SET CORRECTLY PER WORKSHOP MANUAL SECTION 205-02B. NOTE: BACKLASH SHOULD BE CHECKED IN A MINIMUM OF 6 PLACES AROUND THE RING GEAR. IF ALL SERVICE CHECKS HAVE BEEN MADE AND AXLE NOISE IS STILL UNACCEPTABLE, INSTALL DRIVESHAFT XL3Z- 4602-BB. THIS REVISED DRIVESHAFT IS DESIGNED TO REDUCE THE LEVEL OF NOISE PRODUCED BY THE REAR AXLE. EFFECTIVE DATE: 08/19/2003 -------------------------------------------------------------------------------- 16817 2001-2003 F-150 SUPER CREW 4X2 (EXCEPT HARLEY DAVIDSON) - DRIVE LINE VIBRATION / MOAN BETWEEN 55 AND 65 MPH SOME 2001-2003 F-150 SUPER CREW 4X2 (EXCEPT HARLEY DAVIDSON) MAY EXHIBIT A VIBRATION / MOAN BETWEEN 55 AND 65 MPH. A FREQUENCY BETWEEN 80-90 HZ MAY BE HEARD OR FELT IN THE FLOOR PAN OR SEAT TRACK. CK REAR PINION TO DRIVE SHAFT U- JOINT WORKING ANGLE. IF THE U-JOINT WORKING ANGLE IS GREATER THAN 2.5 DEGREES: 1. LOOSEN CENTER BOLT & REPOSITION THE SEAT WEDGE SHIM (THIN SIDE FRONT) BY ROTATING THE WEDGE 180º. 2. TORQUE CENTER BOLT TO 70 +/- 10.5 NM (51.5 +/- 7.5 LB-FT). 3. ASSEMBLE REAR LEAF SPRING TO AXLE WITH NEW U-BOLTS (F7TZ- 5705-AA) & FASTENERS (N620485 S2). THESE MUST BE TORQUED TO 133 +/- 18 NM (98 +/- 13 LB-FT) DURING ASSEMBLY TO ENSURE CORRECT RETENTION. NOTE: IT IS VERY IMPORTANT THAT NEW U-BOLTS AND FASTENERS ARE USED TO ENSURE CORRECT TORQUE 4. VERIFY PINION ANGLE USING THE CHART IN WORKSHOP SECTION 205-00. EFFECTIVE DATE: 05/06/2003 -------------------------------------------------------------------------------- TECHNICAL SERVICE BULLETINS 05-12-06 1997-2005 VARIOUS VEHICLES: REAR AXLE NOISE REPAIR SOME VEHICLES MAY EXHIBIT AN AXLE WHINE OR HUM DURING ACCELERATION, DECELERATION AND/OR CRUISE. AN AXLE REPAIR KIT HAS BEEN DEVELOPED WHICH INCORPORATES MOST PARTS REQUIRED FOR A COMPREHENSIVE AXLE REPAIR. THE KIT SHOULD BE USED INSTEAD OF INSTALLING A COMPLETE AXLE ASSEMBLY TO REPAIR AN AXLE WHINE/HUM. REPLACE RING AND PINION WITH AXLE KIT AND COMPONENTS. See TSB for complete details EFFECTIVE DATE: 06/10/2005 -------------------------------------------------------------------------------- 04-26-06 1997-2005 E-SERIES, F-150, F-SUPER DUTY: CLUNK OR BUMP WHEN STARTING FROM A STOP SOME 1997-2005 E-SERIES/F-150/F-SUPER DUTY 4X2 VEHICLES MAY EXHIBIT A DRIVELINE CLUNK OR BUMP THAT OCCURS AS THE VEHICLE STARTS TO MOVE FORWARD, FOLLOWING A STOP. THIS CONDITION MAY BE CAUSED BY THE SLIP YOKE NOT SLIDING SMOOTHLY ON THE OUTPUT SHAFT SPLINES. LUBRICATE THE SLIP YOKE WITH MOTORCRAFT PTFE LUBRICANT. See TSB for complete details EFFECTIVE DATE: 12/20/2004 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- 597997 - DRIVELINE NOISE CONCERNS SPECIAL SERVICE MESSAGES 18748 MULTIPLE VEHICLES - USE XY-75W140-QL AND XL-3 INSTEAD OF FEHP AXLE LUBE XY- 75W90-QFEHP AND FEHP FRICTION MODIFIER XL-7 MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 07/27/2005 -------------------------------------------------------------------------------- 18740 2003-2006 MULTIPLE VEHICLES - DO NOT APPLY GREASE TO ELECTRONIC THROTTLE CONTROL (ETC) PEDAL ASSEMBLIES DO NOT APPLY GREASE OR SPRAY LUBRICANTS TO ELECTRONIC THROTTLE CONTROL (ETC) ACCELERATOR PEDAL ASSEMBLIES. ACCELERATOR PEDALS ON VEHICLES EQUIPPED WITH ELECTRONIC THROTTLE CONTROL CONTAIN ELECTRICAL COMPONENTS THAT CAN BE DAMAGED BY LUBRICATING PRODUCTS. IF THE PEDAL ASSEMBLY EXHIBITS A CONDITION WHERE LUBRICATION WOULD APPEAR TO CORRECT THE CONCERN, THE PEDAL ASSEMBLY MUST BE REPLACED, NOT LUBED. EFFECTIVE DATE: 07/22/2005 -------------------------------------------------------------------------------- 18510 1997-2005 MULTIPLE VEHICLES - LENGTH OF DIFFERENTIAL BEARING CAP BOLTS IN TSB 05-6-18 REAR AXLE SERVICE KITS MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 03/29/2005 -------------------------------------------------------------------------------- 18250 2000-2005 F-150/E-SERIES/EXPEDITION WITH 4R70W/E OR 4R75W/E - INTERMITTENT CLUNK ON 3-2 DOWNSHIFT DURING COASTDOWN/TIP-IN 2000-2005 F-150, E-SERIES OR EXPEDITION VEHICLES EQUIPPED WITH A 4R70W/E OR 4R75W/E TRANSMISSION MAY INTERMITTENTLY EXHIBIT A SLIGHT CLUNK ON A 3-2 DOWNSHIFT DURING COASTDOWN/TIP-IN UNDER NORMAL DRIVING CONDITIONS. THIS IS A NORMAL CHARACTERISTIC, SO DO NOT ATTEMPT REPAIR. EFFECTIVE DATE: 10/21/2004 -------------------------------------------------------------------------------- 17372 2001-2004 HERITAGE F-150 4X2 WITH 8.8 INCH REAR AXLE - WHINE/HOWL NOISE FROM REAR AXLE MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 12/01/2003 -------------------------------------------------------------------------------- 17064 2002-2003 F-150 4X2 - WHINE/HOWL FROM REAR AXLE MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 08/19/2003 -------------------------------------------------------------------------------- 16817 2001-2003 F-150 SUPER CREW 4X2 (EXCEPT HARLEY DAVIDSON) - DRIVE LINE VIBRATION / MOAN BETWEEN 55 AND 65 MPH MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 05/06/2003 -------------------------------------------------------------------------------- TECHNICAL SERVICE BULLETINS 05-12-06 1997-2005 VARIOUS VEHICLES: REAR AXLE NOISE REPAIR SOME VEHICLES MAY EXHIBIT AN AXLE WHINE OR HUM DURING ACCELERATION, DECELERATION AND/OR CRUISE. AN AXLE REPAIR KIT HAS BEEN DEVELOPED WHICH INCORPORATES MOST PARTS REQUIRED FOR A COMPREHENSIVE AXLE REPAIR. THE KIT SHOULD BE USED INSTEAD OF INSTALLING A COMPLETE AXLE ASSEMBLY TO REPAIR AN AXLE WHINE/HUM. REPLACE RING AND PINION WITH AXLE KIT AND COMPONENTS. See TSB for complete details EFFECTIVE DATE: 06/10/2005 -------------------------------------------------------------------------------- 04-26-06 1997-2005 E-SERIES, F-150, F-SUPER DUTY: CLUNK OR BUMP WHEN STARTING FROM A STOP SOME 1997-2005 E-SERIES/F-150/F-SUPER DUTY 4X2 VEHICLES MAY EXHIBIT A DRIVELINE CLUNK OR BUMP THAT OCCURS AS THE VEHICLE STARTS TO MOVE FORWARD, FOLLOWING A STOP. THIS CONDITION MAY BE CAUSED BY THE SLIP YOKE NOT SLIDING SMOOTHLY ON THE OUTPUT SHAFT SPLINES. LUBRICATE THE SLIP YOKE WITH MOTORCRAFT PTFE LUBRICANT. See TSB for complete details EFFECTIVE DATE: 12/20/2004 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- 702200 - NVH NOISE CONCERN -- REAR SPECIAL SERVICE MESSAGES 18748 MULTIPLE VEHICLES - USE XY-75W140-QL AND XL-3 INSTEAD OF FEHP AXLE LUBE XY- 75W90-QFEHP AND FEHP FRICTION MODIFIER XL-7 MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 07/27/2005 -------------------------------------------------------------------------------- 18510 1997-2005 MULTIPLE VEHICLES - LENGTH OF DIFFERENTIAL BEARING CAP BOLTS IN TSB 05-6-18 REAR AXLE SERVICE KITS MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 03/29/2005 -------------------------------------------------------------------------------- 18250 2000-2005 F-150/E-SERIES/EXPEDITION WITH 4R70W/E OR 4R75W/E - INTERMITTENT CLUNK ON 3-2 DOWNSHIFT DURING COASTDOWN/TIP-IN MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 10/21/2004 -------------------------------------------------------------------------------- 17777 1996-2004 MULTIPLE VEHICLES - REAR LEAF SPRING NOISE SOME 1996-2004 SUPER DUTY F-SERIES/F-150/RANGER, 1997-2004 E-SERIES AND 1999-2004 EXPLORER SPORT TRAC VEHICLES EQUIPPED WITH REAR LEAF SPRINGS MAY EXHIBIT AN INTERMITTENT SPRING SQUEAK/CLUNK WHEN COLD, OR WHEN DRIVING OVER ROUGH ROADS. TO SERVICE: 1)LIFT REAR OF VEHICLE, UNLOADING THE LEAF SPRINGS. 2)PRY OPEN SPRING NEAR LEAF TIP LINER USING A NON-METALLIC WEDGE (RUBBER COATED PRY BAR, WOOD DOORSTOP-TYPE, ETC.). 3)APPLY A FILM OF MOTORCRAFT SILICONE BRAKE CALIPER GREASE XG-3-A TO THE SURFACE OF LEAF TIP LINER (DO NOT USE STANDARD GREASE). 4)REMOVE WEDGE. 5)REPEAT FOR REMAINING TIPS. IF NOISE HAS NOT BEEN ELIMINATED, CONTINUE WITH NORMAL WORKSHOP MANUAL DIAGNOSTICS. NOTE: IT IS VERY IMPORTANT TO USE A NON-METALLIC WEDGE. IF A METALLIC WEDGE IS USED, CORROSION PROTECTION CAN BE DAMAGED. EFFECTIVE DATE: 05/07/2004 -------------------------------------------------------------------------------- 17372 2001-2004 HERITAGE F-150 4X2 WITH 8.8 INCH REAR AXLE - WHINE/HOWL NOISE FROM REAR AXLE MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 12/01/2003 -------------------------------------------------------------------------------- 17064 2002-2003 F-150 4X2 - WHINE/HOWL FROM REAR AXLE MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 08/19/2003 -------------------------------------------------------------------------------- 16817 2001-2003 F-150 SUPER CREW 4X2 (EXCEPT HARLEY DAVIDSON) - DRIVE LINE VIBRATION / MOAN BETWEEN 55 AND 65 MPH MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 05/06/2003 -------------------------------------------------------------------------------- TECHNICAL SERVICE BULLETINS 05-12-06 1997-2005 VARIOUS VEHICLES: REAR AXLE NOISE REPAIR SOME VEHICLES MAY EXHIBIT AN AXLE WHINE OR HUM DURING ACCELERATION, DECELERATION AND/OR CRUISE. AN AXLE REPAIR KIT HAS BEEN DEVELOPED WHICH INCORPORATES MOST PARTS REQUIRED FOR A COMPREHENSIVE AXLE REPAIR. THE KIT SHOULD BE USED INSTEAD OF INSTALLING A COMPLETE AXLE ASSEMBLY TO REPAIR AN AXLE WHINE/HUM. REPLACE RING AND PINION WITH AXLE KIT AND COMPONENTS. See TSB for complete details EFFECTIVE DATE: 06/10/2005 -------------------------------------------------------------------------------- 04-26-06 1997-2005 E-SERIES, F-150, F-SUPER DUTY: CLUNK OR BUMP WHEN STARTING FROM A STOP SOME 1997-2005 E-SERIES/F-150/F-SUPER DUTY 4X2 VEHICLES MAY EXHIBIT A DRIVELINE CLUNK OR BUMP THAT OCCURS AS THE VEHICLE STARTS TO MOVE FORWARD, FOLLOWING A STOP. THIS CONDITION MAY BE CAUSED BY THE SLIP YOKE NOT SLIDING SMOOTHLY ON THE OUTPUT SHAFT SPLINES. LUBRICATE THE SLIP YOKE WITH MOTORCRAFT PTFE LUBRICANT. See TSB for complete details EFFECTIVE DATE: 12/20/2004 -------------------------------------------------------------------------------- 04-02-02 1999-2003 F-150: BODY - BACK GLASS - SLIDING BACK GLASS WINDNOISE/WATER LEAK SEAL REPLACEMENT SOME 1999-2003 F-150 VEHICLES MAY EXHIBIT WINDNOISE AND/OR A WATER LEAK FROM THE BACK GLASS AREA. TO SERVICE, ORDER AND INSTALL SERVICE KIT 3L3Z-1542052-AA. REFER TO THE INSTALLATION INSTRUCTIONS INCLUDED IN THE KIT. IT WILL ALSO BE NECESSARY TO OBTAIN A TUBE OF MOTORCRAFT INSTANT ADHESIVE (TA-19) OR EQUIVALENT FOR THIS REPAIR. See TSB for complete details EFFECTIVE DATE: 01/23/2004 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- 703200 - NVH VIBRATION - ACCELERATION SPECIAL SERVICE MESSAGES 18748 MULTIPLE VEHICLES - USE XY-75W140-QL AND XL-3 INSTEAD OF FEHP AXLE LUBE XY- 75W90-QFEHP AND FEHP FRICTION MODIFIER XL-7 MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 07/27/2005 -------------------------------------------------------------------------------- 18510 1997-2005 MULTIPLE VEHICLES - LENGTH OF DIFFERENTIAL BEARING CAP BOLTS IN TSB 05-6-18 REAR AXLE SERVICE KITS MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 03/29/2005 -------------------------------------------------------------------------------- 18250 2000-2005 F-150/E-SERIES/EXPEDITION WITH 4R70W/E OR 4R75W/E - INTERMITTENT CLUNK ON 3-2 DOWNSHIFT DURING COASTDOWN/TIP-IN MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 10/21/2004 -------------------------------------------------------------------------------- 17372 2001-2004 HERITAGE F-150 4X2 WITH 8.8 INCH REAR AXLE - WHINE/HOWL NOISE FROM REAR AXLE MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 12/01/2003 -------------------------------------------------------------------------------- 16817 2001-2003 F-150 SUPER CREW 4X2 (EXCEPT HARLEY DAVIDSON) - DRIVE LINE VIBRATION / MOAN BETWEEN 55 AND 65 MPH MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 05/06/2003 -------------------------------------------------------------------------------- 16666 2000-2003 F-150, 2000-2003 EXPEDITION/NAVIGATOR - ADJUST ROOF OPENING PANEL WIND DEFLECTOR SOME 2001-2003 F-150 SUPERCREW, 2000-2003 F-150 SUPERCAB, AND 2000-2003 EXPEDITION/NAVIGATOR MAY EXHIBIT A WIND NOISE/BOOM WHEN DRIVEN AT HIGHWAY SPEEDS ABOVE 55 MPH WITH THE ROOF OPENING PANEL FULLY OPEN. THIS MAY BE DUE TO THE OPENING PANEL WIND DEFLECTOR NOT BEING DEPLOYED HIGH ENOUGH ABOVE THE ROOF LINE. TO SERVICE, ADJUST AS FOLLOWS: 1. OPEN PANEL TO THE FULLY RETRACTED POSITION. 2. PULL UP ON THE WIND DEFLECTOR IN THE AREA OF THE TWO NYLON STRAPS (NO MORE THAN APPROXIMATELY 10 LBS OF FORCE SHOULD BE NECESSARY). THE STRAPS WILL SLIGHTLY DEFORM IN THE AREA WHERE THEY ARE ATTACHED TO THE WIND DEFLECTOR AND EFFECTIVELY 'STRETCH' BY ABOUT 2 MM. THIS WILL ALLOW THE DEFLECTOR TO DEPLOY HIGHER ABOVE THE ROOF LINE, ELIMINATING THE WIND NOISE BOOM. EFFECTIVE DATE: 03/03/2003 -------------------------------------------------------------------------------- TECHNICAL SERVICE BULLETINS 05-12-06 1997-2005 VARIOUS VEHICLES: REAR AXLE NOISE REPAIR SOME VEHICLES MAY EXHIBIT AN AXLE WHINE OR HUM DURING ACCELERATION, DECELERATION AND/OR CRUISE. AN AXLE REPAIR KIT HAS BEEN DEVELOPED WHICH INCORPORATES MOST PARTS REQUIRED FOR A COMPREHENSIVE AXLE REPAIR. THE KIT SHOULD BE USED INSTEAD OF INSTALLING A COMPLETE AXLE ASSEMBLY TO REPAIR AN AXLE WHINE/HUM. REPLACE RING AND PINION WITH AXLE KIT AND COMPONENTS. See TSB for complete details EFFECTIVE DATE: 06/10/2005 -------------------------------------------------------------------------------- 04-26-06 1997-2005 E-SERIES, F-150, F-SUPER DUTY: CLUNK OR BUMP WHEN STARTING FROM A STOP SOME 1997-2005 E-SERIES/F-150/F-SUPER DUTY 4X2 VEHICLES MAY EXHIBIT A DRIVELINE CLUNK OR BUMP THAT OCCURS AS THE VEHICLE STARTS TO MOVE FORWARD, FOLLOWING A STOP. THIS CONDITION MAY BE CAUSED BY THE SLIP YOKE NOT SLIDING SMOOTHLY ON THE OUTPUT SHAFT SPLINES. LUBRICATE THE SLIP YOKE WITH MOTORCRAFT PTFE LUBRICANT. See TSB for complete details EFFECTIVE DATE: 12/20/2004 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- 703400 - NVH VIBRATION - DECELERATION SPECIAL SERVICE MESSAGES 18748 MULTIPLE VEHICLES - USE XY-75W140-QL AND XL-3 INSTEAD OF FEHP AXLE LUBE XY- 75W90-QFEHP AND FEHP FRICTION MODIFIER XL-7 MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 07/27/2005 -------------------------------------------------------------------------------- 18510 1997-2005 MULTIPLE VEHICLES - LENGTH OF DIFFERENTIAL BEARING CAP BOLTS IN TSB 05-6-18 REAR AXLE SERVICE KITS MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 03/29/2005 -------------------------------------------------------------------------------- 18250 2000-2005 F-150/E-SERIES/EXPEDITION WITH 4R70W/E OR 4R75W/E - INTERMITTENT CLUNK ON 3-2 DOWNSHIFT DURING COASTDOWN/TIP-IN MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 10/21/2004 -------------------------------------------------------------------------------- 16817 2001-2003 F-150 SUPER CREW 4X2 (EXCEPT HARLEY DAVIDSON) - DRIVE LINE VIBRATION / MOAN BETWEEN 55 AND 65 MPH MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 05/06/2003 -------------------------------------------------------------------------------- 16666 2000-2003 F-150, 2000-2003 EXPEDITION/NAVIGATOR - ADJUST ROOF OPENING PANEL WIND DEFLECTOR MESSAGE TEXT DISPLAYED UNDER A PRIOR CODE EFFECTIVE DATE: 03/03/2003 -------------------------------------------------------------------------------- TECHNICAL SERVICE BULLETINS 05-12-06 1997-2005 VARIOUS VEHICLES: REAR AXLE NOISE REPAIR SOME VEHICLES MAY EXHIBIT AN AXLE WHINE OR HUM DURING ACCELERATION, DECELERATION AND/OR CRUISE. AN AXLE REPAIR KIT HAS BEEN DEVELOPED WHICH INCORPORATES MOST PARTS REQUIRED FOR A COMPREHENSIVE AXLE REPAIR. THE KIT SHOULD BE USED INSTEAD OF INSTALLING A COMPLETE AXLE ASSEMBLY TO REPAIR AN AXLE WHINE/HUM. REPLACE RING AND PINION WITH AXLE KIT AND COMPONENTS. See TSB for complete details EFFECTIVE DATE: 06/10/2005 -------------------------------------------------------------------------------- 04-26-06 1997-2005 E-SERIES, F-150, F-SUPER DUTY: CLUNK OR BUMP WHEN STARTING FROM A STOP SOME 1997-2005 E-SERIES/F-150/F-SUPER DUTY 4X2 VEHICLES MAY EXHIBIT A DRIVELINE CLUNK OR BUMP THAT OCCURS AS THE VEHICLE STARTS TO MOVE FORWARD, FOLLOWING A STOP. THIS CONDITION MAY BE CAUSED BY THE SLIP YOKE NOT SLIDING SMOOTHLY ON THE OUTPUT SHAFT SPLINES. LUBRICATE THE SLIP YOKE WITH MOTORCRAFT PTFE LUBRICANT. See TSB for complete details EFFECTIVE DATE: 12/20/2004 -------------------------------------------------------------------------------- *714 304 325* TECH HOTLINE CONTACT ID EXPIRES IN 5 DAYS FOR 1FTRW07633KB61046 END OF OASIS REPORT FOR 1FTRW07633KB61046
thanks man..alot of info there
No problem. thats all the info on the F-series rear end. Pretty crazy huh. If you have any more problms just let me know and i will see if there are TSB's for them.
Look Ma! My First Post!
I've got a 02 F150 SuperCrew (1FTRW086X2KC57205 , axle:H9)with a pretty noise rear end (sounds like bearings without any grease, any speed, with or without brakes, any load). I've had the truck to two shops, one private one dealership and both have said it's the rear end. The private shop want to rebuild the entire rear end for $1000 (says, once he's in, should just do the whole thing). The dealership is telling me $800 for the bearings and then more if anything else needs to be replaced. So, a few questions... - Is there any reason to go to the dealer. It seems like this is a pretty easy problem to spot and that the any reputable shop can do it (no secrets to how a differential works?). - The private shop said he could do just the bearings for about $600. Should I ask him to check the gears but only replace the bearings? - Seems like this rear end is not the most reliable. Should I consider an aftermarket alternative? I pull a 3000 lbs trailer about 600 miles a year, otherwise I drive it like it's a car. Thanks Paul |
I'll PM you
Threads Similar to: Casper... My Truck
| casper for u | noppe180 | 96-98 | 4 | May 4th, 2007 12:58 AM |
| Casper | 97_4.6L_Stang | 96-98 | 16 | May 2nd, 2007 07:25 PM |
| Casper | nHuman | 96-98 | 1 | March 23rd, 2007 08:41 AM |
