Discussing Patriot Heads? in the 99-04 Forum. Stage II Patriot Performance heads and a comp XE262AH cam. The heads will be $1295 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Patriot Heads?
Stage II Patriot Performance heads and a comp XE262AH cam. The heads will be $1295 and the cams will be $575.00.....this is what the guy from patriot performance said would work well with my car, are there heads good or should i buy from someone else. I want the cam to be big enough to give me a very mean lope so is this cam big enough.
2001 mustang gt 5 speed Full bolt ons with 4.10 gears. 1965 Mustang 302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter. In the process of restoring it... |
Maintenance Man
11.47@120.58
Patriot Used To Have A Bad Reputation
Patriot used to have a bad reputation a few years ago but it's much better now. They sell some pretty good heads for the money.
go with the VT stage 2 N/A cams. thay have a 108 LSA a mean lope
![]() ![]() http://www.youtube.com/v/H4yshtsVTH4&rel=1
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs |
03 mustang GT
7.28 in 1/8th
Patriot heads are pretty good. That's what I have. Just check the plugs in the back of them that block off the unused oil passages and make sure they're tight. The VT cams have a more aggressive chop to them and they don't have a 5 degree advance ground into them so you don't have to degree them when you install them.
506 rwhp. Procharger, nx nitrous kit, bla bla bla
I'd reccomend xe270 cams...i have em and i love em...Actually...I've got a video of the idle here:
Save your money !!! Patriot bought all the heads from ford that were not even up to fords standards to use, they are called Blems (short for blemish). They say they have resolved their troubles, do you really want to chance finding out the hard way. Do a search on most any forum you'll see dozens of failures.
1999 Mustang GT
don't notice any cam lope on stang up there...
I have 270's on my 5.5L. They're great for my combo. Lope is mild but definitely there.
#9 | |
1999 Mustang GT
1997 Mustang GT
13.56@102.94
I hear VT Engines is having problems, so I wouldn't send any money their way until things get fixed.
Trouble at VT Engines - Modular Depot Forums
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.04 60ft 13.56@102.94 all on stock 245-17's My Garage |
From what i have read foxlake would be the way to go
2004 Black Mustang Gt"I'm a agent of chaos" -Joker,Dark Knight |
"Slow Ass Car"
SLOW
Patriot Heads are junk in my book...I know they have supposedly fixed all the valve issues and such that were giving them issues but I am still hearing the horror stories...
Im going with a set of 2.5 heads from Modular PowerHouse They have the best heads hands down IMHO... Steen Racing Website also have some AWESOME heads from what I ahve seen and heard...Actually Steen is going to be building MPH's heads comign here soon... |
This is fact, you may not believe it but it is true. Ford had 1000's that had issues that could have led to a major recall. I know I could still pick these heads up myself, why would I want to use junk.
Well with the tune the idle set so high its not as noticeable as it used to be.. I used to have the stock idle at about 750-800 rpms and the lope caused to to lose vacuum and shut off.. So i had it retuned to idle at 900rpms after warmup...But view a vid of a stock mustang.. you should notice a difference.
And btw, the heads i have are Steen Racing Stage 2 heads...I agree w/ chris..Awesome.. Last edited by StangAddiction : November 23rd, 2007 at 07:05 PM. |
1999 Mustang GT
^ I have cams as well....
unstoppable @ speed of light
Boss330 racing. He's in Vero Beach FL and has a great reputation with modular engine work. I think he's pretty expensive but never heard a single bad thing about his work.
Boss330 Racing > Home The web site is unfinished and sucks, but it's got a contact # on it.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
03 mustang GT
7.28 in 1/8th
You guys do know that noone makes an aftermarket head for the 4.6 right? They are all ford heads that have been ported with the springs and valves changed. What exactly were the problems Patriot was having with there heads?
#18 | |
03 mustang GT
7.28 in 1/8th
#19 | |
"Slow Ass Car"
SLOW
Some issues just to name a few...Warped heads coming out of the box...Sparkplug threads falling out of the heads right out of the box...Bad valves...Exessive oil consumption...And many more...They say they have fixed the issue but from what I have seen and heard they are far from being fixed... |
All Throttle with a Bottle
12.36@110 with d/a of 8330 ft
I will never put anything that says patriot on my car. To many bad stories about them!
![]() 1996 Mustang GT with a 351 swap with Stalled C4 1997 F250 Powerstroke 1999 28' Classic Dominator http://www.moddedmustangs.com/forums...-part-3-a.html Thanks to: Andrews Racing Transmissions |
Threads Similar to: Patriot Heads?
| patriot stage 3 heads for 97 4.6L????? | AztecGold | 96-98 | 1 | July 20th, 2007 12:18 PM |
| Patriot Cylinder Heads.....???? | jwarnick | 96-98 | 2 | June 30th, 2007 11:08 PM |
| Patriot cylinder heads | acmillr | 99-04 | 12 | June 27th, 2007 06:57 AM |
| Patriot Performance Heads | CantDrv55 | 99-04 | 2 | March 17th, 2007 11:51 PM |
| Patriot stage 3 heads. | MySallyMI | 99-04 | 9 | February 19th, 2007 11:08 AM |
