Rpms
just thought id give a check to make sure i have stock gears in my car, so i dont waste my time buying them, in fifth gear 80 MPH what RPMs should my car be at, i have a 03 mach 1 5 speed, i beleive they come stock with 3 55s
99 Cobra 03 Cobra motor AFCO H/E Pulley JLT CAI BBK L/T off road H/steeda catback SCT MAF Tune 03 cobra pumps HVGC |
2002 Chevrolet Impala
what size tires do you have?
With the stock tires and stock 3.55 gears you should be turning around 2300-2350 rpm at 80 mph.
Here's a link to my speed/gears calculator...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
#4 | |
2001 Mustang SVT Cobra
someone made a real nice thread on this. It should be a freaking sticky!
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
12.73@111.36
You can't check it by speedometer versus tachometer unless your car has had the computer recalibrated for your setup.
The best way to check gears is to jack up the back of the car. Put the car in neutral. Place a mark on the driveshaft and one tire. As you turn the tire, count the number of time the driveshaft goes around. For example, if the driveshaft turns 3 1/4 times for one full turn of the wheel then you have 3.27 gears. It it turns, just over four time then you have 4.10s. Just under is 3.73s. If you have 3.55s then the driveshaft should go around 3 1/2 times for one full rotation of the tire.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
48.47@ 12.58
or drive with a GPS on. that will tell you your true speed
Threads Similar to: Rpms
| Vibration at low RPMS..... hmm | Ole Yeller | V6 Mustangs | 8 | June 15th, 2007 05:53 PM |
| 7500 rpms? | matfernan1 | 99-04 | 10 | June 14th, 2007 01:36 PM |
| Ford C-6 rpms | dr.gonzo! | 5.0 Mustangs | 7 | June 9th, 2007 02:03 AM |
| HELP, Car shakes bad over 2,800 rpms | YNOT | 5.0 Mustangs | 18 | April 16th, 2007 06:38 PM |
| dropping rpms | rocket | 5.0 Mustangs | 6 | August 21st, 2006 09:46 PM |
