Dyno results 2004 Supercharged Saleen with mods
Well, got back from the dyno and I'm VERY happy with the results!!!
When the car was on the dyno last it put down 306 rwhp / 340 rwtq. Today I put down 361 rwhp / 392 rwtq. With the stock pulley we previously saw 9.5 lbs of boost. Today I was able to see a little over 12 lbs of boost with the Chicane 2.97" pulley. What I changed from my last dyno session... - 03/04 Cobra dual fuel pumps and baffled tank over stock GT tank and pump - FRPP 42 lb injectors over Saleen 30 lb injectors - Chicane 2.97" Pulley over stock 3.125" Pulley - SCT Xcal2 tuned over stock Saleen PowerFlash tune Two things...the Cobra fuel pump is awesome as I had no fuel delivery issues whatsoever. Bad news is I pegged the stock meter (we saw 5 volts at about 5800-5900 rpm). Also, my inlet air temperature was high (over 130 degrees). So, overall I'm happy. Down the road I'll be swapping in an SCT Big Air MAF, Magnaflow X-Pipe, and 3.73 gears. Unfortunately, I don't have a scanner for the dyno graph, but here are a couple pics from the dyno session. My car did great today, my truck not so hot. It only put down 388 rwhp / 402 rwtq (2005 Dodge Ram 1500 Rumble Bee). I was hoping for mid 400 numbers but I've got lean A/F issues up top that precluded us from making full pull runs. ![]() ![]() I've got more pics of my car on my CarDomain page located here... CarDomain Garage
- Rob 2010 Kona Blue Shelby GT500 Coupe |
11.47@120.58
that's a beautiful car, congrats on the nice #s
Zoolander
04 Cobra #2260/3768 1/820
Gorgeous car. I noticed you live in VA beach. Where did you get your dyno done? I'm looking for a dyno that is relatively close by that I can go to for when I get my gt.
#4 | |
#6 | |
820 Greenbrier Circle #15 Chesapeake, VA 23320 757 549-DYNO (3966) Email: dtp@dtpracing.com Brent and Frank are both great guys. Brent knows how to tune and did both my car and truck several times with excellent results! Not sure where you're coming from on I-64...but take the Greenbrier Pkwy North Exit. The first stop light is Woodlake Drive (make a right). It becomes Greenbrier Circle. Look on the left for Building Set 820. There are two entrances...go to the second entrance. Look for DTP Racing on the window. They are Suite Number 15. Brent will have his huge red Dodge Ram dually, some Vettes, and Mustangs parked in front.
Zoolander
I work off on greenbrier parkway. I don't need to take the interstate. Thank you so much though. That place isn't far at all. If traffic isn't bad I can get there in 15-20 minutes.
that saleen is one sweet car! good looking numbers your putting down, when are you going to the track?
1999 GT Rag
nice license plate :wink
and nice numbers to go with a nice ride
#10 | |
about what is the cost of a session?....I'm up in richmond and we don't have much to choose from here
Three pulls and A/F readings plus a dyno graph printout comes to $75. That is pretty much the standard cost wherever you go. Some shops charge less. If you get a group of guys to go for a dyno day it can usually get a lot cheaper.
#14 | |
Re: Dyno results 2004 Supercharged Saleen with mods
Thanks, I'll try some NGK TR6's gapped at 0.35, and a 180 Degree thermostat.
I'm already looking into an X-pipe...possibly some long tubes.
#16 | |
It would not be a bad idea to get a Lightning MAF either. The X-pipe sounds good if it's not raspy (almost sounds like an exotic on highways). I'm putting a thermostat in my car tonight or tomarrow. It looks like it's really easy to do, just two bolts. I got an SLP thermostat from LM performance. It's a good idea to makesure your fans turn on a little sooner, especially since the water flows sooner (this can be adjusted with the tuning software). I noticed a significant improvement with a 75mm Throttle body. The Supercharger Inlet looks as if it was almost made for that size. I put it on in a parking lot with some basic tools in about a half hour. Piece of cake. I got an accufab. Chicane either does or will offer an intercooler upgrade. You could always get your intake manifold ported by extrude hone (the intake manifold is generally considered the main factor keeping the saleen supercharger from hitting kenne bell numbers). Also, I've heard good things came from switching the front heat exchanger (for intercooler) with the one from Lightning Performance. Finally, I actually heard someone got some marginal power with a radiator upgrade on these cars. I can only assume that this is because heat is an issue with these blowers under boost. I noticed you got the center exhaust. Any other upgrades? |
fallstar...mods are listed in my CarDomain page or my SaleenPower garage.
Here are the links... My SaleenPower Garage My CarDomain Page I've already got the Accufab 75mm throttle body...had issues at first with high idle, but I've since had that fixed. Great mod as you state! Thanks for the insight on the other mods...I'll check them out!
I'm pretty close to you as far as mods are concerned but i'm at 381rwhp and 384 torque. I'm guessing it's the X-pipe that adds power but lowers torque.
1999 GT Rag
the only torch red eh?... :award
Dang, Rob.......nice #s :award
Threads Similar to: Dyno results 2004 Supercharged Saleen with mods
| Dyno Results? | Wally1968 | 2005 - 2010 | 35 | November 21st, 2007 01:21 PM |
| My Dyno Results | WAVEBYE | The Clubhouse | 46 | October 25th, 2007 09:47 PM |
| Dyno results in!! | stanglifemike | 2005 - 2010 | 35 | September 20th, 2007 10:05 PM |
| Dyno Results 06 GT Supercharger With 20's | Pro Form | 2005 - 2010 | 56 | August 14th, 2007 05:26 AM |
| My DYNO results are in!! | Bossman | 2005 - 2010 | 18 | February 7th, 2007 07:34 PM |
