Discussing Ok So... (Oil Change) in the 99-04 Forum. I would not recommend running anything other than the recommended viscosity in an engine except ...
Old November 29th, 2007, 05:15 AM   #41
dansgt's Avatar
2003 Mustang GT
I would not recommend running anything other than the recommended viscosity in an engine except for cases where the engine has very high millage (over 150k). the manufacture recommends a certain viscosity based on the clearances inside of the engine, when it is new the clearances are very tight and the thicker oil will not flow through the tight gaps as well as the thinner oil will. this will cause premature engine wear and lead to early failure to internal engine components.
as for the synthetic switch, the problem with it in a higher millage is it cleans it too well. the regular oil deposits particles in the small clearances of the engine and gaskets, when you run the synthetic, you remove all this and could bring up leaks in the engine where parts of the conventional oil had sealed it. the problem that someone mentioned earlier with the particles getting stuck in the filter is preventable, run the synthetic for a week or so and than change your oil and filter. But overall, dont switch to a full synthetic oil unless the car was broken in on it, go with a synthetic blend. over 75k miles or so i'd recomend just sticking to conventional oil, especially if you have any leaks on the engine, they'll just get worse with synthetic.
Old November 29th, 2007, 12:05 PM   #42
chris1's Avatar
2003 Ford Mach
Traveling at the speed of a photon
Originally Posted by 00SlvrStang View Post
Both of the oils you mentioned are NOT synthetics anymore. They are made from regular oil but considered synthetics. If you want a true synthetic go with RP or Amsoil.
unless you have an infinite amount of reserves from when they did sell true synthetic..lol
Under my Umbrella!
Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome.
Old November 29th, 2007, 04:55 PM   #43
Cesar2cool's Avatar
2003 Mustang GT
Ok so im switch back to 5W20 But how many quarts do i need 2 get?
Originally Posted by GearedGT View Post
Raw to fast, RAW to FURIOUS. I'M TO FAST FOR YA'LL MANG!!!!!!
goddamnit.
www.myspace.com/usmc03gt
Old November 29th, 2007, 04:56 PM   #44
Garhfer's Avatar
2004 Mustang GT Conv.
mine takes 6.5
2004 GT Boosted by Vortech
Old November 29th, 2007, 04:57 PM   #45
Cesar2cool's Avatar
2003 Mustang GT
so buy 7 quarts in other words?
goddamnit.
Threads Similar to: Ok So... (Oil Change)
Oil Change BoomerSixZero Classic Mustangs 4 July 1st, 2007 11:10 PM
Maybe I should change my name... turp The Clubhouse 26 June 3rd, 2007 01:05 AM
Something has got to change! kobebryant V6 Mustangs 69 April 23rd, 2007 04:30 PM
change it up kaizerdan Visual 12 January 11th, 2007 07:15 PM
name change QuEeNiEsTaNg V6 Mustangs 1 December 17th, 2006 08:37 PM
