3 Inch Exhaust
Old November 26th, 2007, 11:40 AM   #1
Xantho99's Avatar
Xantho99 is on a distinguished road
Send a message via AIM to Xantho99
3 Inch Exhaust
Honestly, will running 3 inch exhaust on my 02 GT really hurt anything? I am more concerned about the sound of the car than the power right now.
I'm planning on:
-Long tube headers w 3 inch collector
-3 inch H pipe
-3 inch 40 series flowmasters, dumped
2002 GT
Old November 26th, 2007, 11:41 AM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you don't really need 3 inch unless you plan on making LOTS of power.
Old November 26th, 2007, 11:47 AM   #3
Xantho99's Avatar
Define lots of power
2002 GT
Old November 26th, 2007, 11:53 AM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Old November 26th, 2007, 12:10 PM   #5
Xantho99's Avatar
so my question is: will it hurt my engine by running 3 inch exhaust?
2002 GT
Old November 26th, 2007, 12:12 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you might loose a bit of TQ but other than that it won't hurt you
Old November 26th, 2007, 01:07 PM   #7
00SlvrStang is on a distinguished road
you will definately lose some power on the low end but it wont hurt the car
Old November 26th, 2007, 01:09 PM   #8
WilltheThrill's Avatar
Saving up for another one
WilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura about
you might loose a bit of TQ but other than that it won't hurt my feelings.
Yes those are cobra R replica mustang wheels on my 300zx
03 Cobra- gone but not forgotten
90 Nissan 300zx
00' Yamaha YZF 600
Originally Posted by '97'Cobra View Post
I was too drunk even tell which hole i was gettin after.
Old November 26th, 2007, 02:42 PM   #9
Xantho99's Avatar
someone said that it would burn my valves...
2002 GT
Old November 26th, 2007, 03:20 PM   #10
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
They are concerned that it will run lean from that. More flow means more air, and a potential miss reading of the engine computer and leaning out the fuel. It shouldn't be an issue. If anything I would think it might go rich. Either way, a tune would take care of any issues. Get it tuned and enjoy the MUCH LOUDER sound.
Old November 26th, 2007, 07:31 PM   #11
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
It won't increase "flow", the engine can only pump so much air/exhaust gas; and that's the root of the problem; the flow volume will stay the same and the flow velocity will decrease.
A 3" exhaust (44% larger area than a 2-1/2" pipe) will do is significantly reduce the velocity of the exhaust gasses--and then, aside from reducing the low pressure "wake" behind each exhaust pulse, it will allow the gasses to expand faster (and cool), The larger diameter pipe will also radiate heat better and further cool the gasses.
So, "Who cares of my exhaust gasses are cooler?"
You should, because exhaust gas is a fluid and like any fluid it thickens as it cools. Thicker means more power is required to push it out the tailpipe, and more power required to push it out the tailpipe = less power to make the car GO...
BTW--2-1/2" (what I and most others are running) is arguably too big for an n/a 4.6 L dual exhaust, however no one makes 2-1/4" or 2-3/8" stuff and it's not really that much too big to matter. 3" on an n/a engine would be "too big enough" to matter.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old November 26th, 2007, 07:37 PM   #12
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
That's why you get less power with open headers------LOL
I see the misinformation is still bountiful on this board.
Old November 26th, 2007, 07:40 PM   #13
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
i have 2 and a half on my truck to 3'' single chamber flows.. didnt make any difference
FX4 Crew
Crew member #3
Old November 26th, 2007, 07:51 PM   #14
cliffyk's Avatar
Open headers are NOT an exhaust system, study up on fluid dynamics first then come back and hurl insults...
Edit: Hook those same headers up to a set of pipes that's too large or too long and power will suffer...
-cliff knight-
My Mustang
Old November 26th, 2007, 07:57 PM   #15
MM's Mad Scientist
acmillr's Avatar
Slow Fella
You mean like for two or three years at a university?? However, I was not trying to insult you personally. The guy asked a question- "will 3" exhaust hurt me?" The answer is NO on his set up. There's way too much rationalization going on here.
Old November 26th, 2007, 08:07 PM   #16
cliffyk's Avatar
I apologise if I come off as an engineer/engineering professor--problem is I am (MSME MIT '71 and never stopped learning since then).
Too large a diameter exhaust pipe will hurt power output for the reasons stated; it may not do it to an extent that anyone (but me) would care, but it will do it nonetheless...
-cliff knight-
My Mustang
Old November 26th, 2007, 08:09 PM   #17
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Let's be friends anyway........... LOL.
BTW> No engineer here. Just pullin your chain.
Old November 26th, 2007, 08:11 PM   #18
mattstang's Avatar
so engineers what do you need to have to take advantage of a 3" setup
FX4 Crew
Crew member #3
Old November 26th, 2007, 08:13 PM   #19
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ something other than a 2v
so yea.. all this adds up to is.. you will lose a little TQ.
Old November 26th, 2007, 08:14 PM   #20
mattstang's Avatar
hey i said engineers not docs so GTFO
sorry doc
FX4 Crew
Crew member #3
Threads Similar to: 3 Inch Exhaust
67 mustang 8 inch or 9 inch? My67_fastback Classic Mustangs 15 June 25th, 2008 08:29 AM
different between 8 and 9 inch mustangrebuilder Classic Mustangs 14 July 29th, 2007 08:10 AM
3 inch into 2.5 inch what to do Badasstang281 99-04 2 January 5th, 2007 06:01 AM
12 Inch Sub Box adam007g Audio/Video 4 September 26th, 2006 07:05 PM
3 inch or 2.5 inch OTreborO General Tech 4 September 23rd, 2006 10:49 PM
