Camshaft Question
Old November 27th, 2007, 03:01 PM   #1
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
Camshaft Question
Well Cams and heads (either ported and polished stocks or some patriot heads) and i have a few questions. What exactly is a lift? duration? and everything else associated with cams? Just tell me pretty much everything you know. What is the difference between stage 1 2 and 3 cams?
I've heard that you should go with a stage 2 cam with some new springs. Are they something you can do yourself?
Old November 27th, 2007, 04:28 PM   #2
2001 mustang GT
12.90@109.07
kennyGT is on a distinguished road
Send a message via AIM to kennyGT
dont have all the answers to your questions but this is caspers thread of a cam swap
Cam Swap On SOHC 4.6 1998 GT
88 LX automatic-non stroked 302 with iron heads
01 GT manual-h-pipe bullets dumped-125shot
97 GT automatic-SOLD
Old November 27th, 2007, 04:44 PM   #3
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
i just know the very basic is that with a bigger cam your valvues for intake and exhaust stay open longer...depending on the size of lift to allow more air in and push more air/exhaust out, giveing more power. And it sounds cool at idle!!
Old November 27th, 2007, 05:32 PM   #4
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Go to Comp cams website and start reading.
Old November 27th, 2007, 09:07 PM   #5
ok, will do.
Sending you a PM
Old November 27th, 2007, 11:54 PM   #6
Proud American
MustangMatt96GT's Avatar
I learned alot doing that, and then also by reading more when i can.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old November 27th, 2007, 11:54 PM   #7
How hard is it to install a pair of cams? If i do it myself i'll probably do a cam that i dont have to go into the heads to install new springs...
Old November 27th, 2007, 11:55 PM   #8
MM's Mad Scientist
acmillr's Avatar
Slow Fella
It is not a difficult task. It just takes some planning and patience.
Old November 27th, 2007, 11:56 PM   #9
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
+1
is it possible to do these springs with the head on the car?
FX4 Crew
Crew member #3
Old November 27th, 2007, 11:57 PM   #10
Proud American
Its realavitly easy. Timing them is the most crutial part. For the first timer I suggest taking off the timing cover, but that is not required. But if you go for a semi radical cam, you will have to do valve springs, and will give you more problems.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old November 27th, 2007, 11:58 PM   #11
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Possible, but a real PITA............ The size of the springs and the distance to the camshaft pillars makes it difficult to remove the springs.
Old November 27th, 2007, 11:58 PM   #12
Proud American
Originally Posted by mattstang View Post
+1
yes, an attachment to an aircompressor that screws into the spark plug hole, so that the valves dont drop is needed but thats it.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old November 28th, 2007, 12:00 AM   #13
1996 mustang gt
gtdan is on a distinguished road
Send a message via Yahoo to gtdan
for what type of cams would you need to change the springs and such???
Old November 28th, 2007, 12:01 AM   #14
any cam with a high lift
Old November 28th, 2007, 12:02 AM   #15
mattstang's Avatar
kinda what i was thinking. then if for some reason you drop one the heads gotta come off anyway
FX4 Crew
Crew member #3
Old November 28th, 2007, 01:32 AM   #16
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
if the piston is at tdc the valve won't fall enough that you can't retrieve. if you have the otc tool it makes life easier to change springs.
did not mention year of car but if you get apiece of 1" pipe slightly longer than the length of the cams and use the tool it makes it much easier to change springs on car.
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old November 28th, 2007, 02:31 PM   #17
04 MUSTANG GT
14.5 @ 97.2
MIKE 04 GT is on a distinguished road
What Is A Good Cam To Choice. I Was Thinking On A Comp Cam (xe 262)
Old November 28th, 2007, 02:39 PM   #18
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Comp grinds some excellent cams. Having said that, I would either opt to have Comp cut some custom cams or get some cams from Hi-tech. It is my opinion that the off-the-shelf Comp cams have a little too much lobe seperation to maximize NA performance. If you would like to have them grind you a pair of custom cams, I would be more than happy to PM what I would think is the best grind for your application.
Threads Similar to: Camshaft Question
Best Camshaft For 347? tehdwarvenn 5.0 Mustangs 20 November 21st, 2007 12:23 AM
Question about camshaft BumbleBeeStang04 99-04 16 September 12th, 2007 02:06 PM
Camshaft question energiesource 99-04 3 July 28th, 2007 06:29 PM
camshaft new 5.0 94-95 3 March 17th, 2007 12:33 PM
Camshaft for a 96 94pacecarSVT V6 Mustangs 2 February 1st, 2007 12:24 AM
