2001 mustang bullitt
Pics Of Installs
here are some pics of the goodies i am installing!!
2001 bullittmmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds. |
here are some more.
this is the intercooler i mounted.
Woah! that looks pretty badass
Looks sick man cant wait to see it in action.
01 Mustang GT | 5 Speed | Bullitt Intake | 4.10's | Diablo Tuner | JLT CAI | Flowtech LT Headers, bbk catted H, dynomax catback | 01 Carbon Black BMW M3 w/dynomax exhaust
once i get the supercharger payed off i am having a forged mmr 4.6 with patriot stage 2 heads so i can run 20 psi of boost and i will more than likely run a 75 shot but not sure yet about nitrous,still kicking it around.
thats a nice set-up!
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
lookin good bro and btw you have a really sharp bullitt
Cigar Assassin
tre' sweet brah
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
2002GT Vert.
![]() iTrader: 1 reviews
nice !
![]() 02 GT vert-True Blue w/Black staggered FR500's Trick One springs. MGW shifter. Flowmasters. Steeda Wing. Mach 1 chin/grille. CAI. Pulleys. SCT Tune.+ more in the boxes waiting to go on. Topless Mustang Club |
How do you like that manifold? Also what does it run (cost)?
I run a Novi 2000 as well but with no inter-cooler @ 8psi (sent off for rebuild and pully upgrade though). Dont be shocked but unless you are running 18-20 psi that will rob you of quite a bit of power. The blower is so large that is isnt really working unless its spinning at high PSI levels. So the intercooler is just further routing already "cool" air and taking away some gains. That is only at lower boost levels though. If you plan on going o 20 then you will end up getting very good use out of it. Either way 8psi is still a lot of fun. Are you running any internal or head work? Car looks good and looks like it will be a monster very soon.
www.fquick.com/Nates4.6 Last edited by Nate's4.6; November 28th, 2007 at 08:53 AM. |
nice I cant wait till I get my F/I sweet man!
#12 | |
Oh nice job dcrow on your car. Looks nice!
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. Last edited by gsjohnson; November 28th, 2007 at 09:06 AM. |
#13 | |
And yes the Novi 2000 responds a bit different do to the deign of their intercooler. Remember the Novi 2000 is Paxtons biggest street blower. It is good to 29 PSI. So at 8 psi it is barely evening turning and not really producing that much heat. If you had the 1000 verson this would be a bit different but then you are limited on how far you can push your blower. If you have big things in mind (and run a Paxton). then the Novi 2000 is for you. If you only plan on running 8 psi and thats it, then I would suggest the 1000 model. I am bumping up to 12-16 psi right now (havent made up my mind). For now I am forgoing a intercooler. I plan on doing a few other things to keep temp down but if I do not need a intercooler I am not going to install one. If I was thinking of going into the 18+ psi levels though I would not do without one (never plan on going that with that much boost).
www.fquick.com/Nates4.6 |
Nice set up...how much power are you putting?
13.9@101
Didn't cost him anything, he has a bullitt
![]() 13.9@101 before some mods |
Shit...just knoticed that. I thought it was a GT for some reason. Oh well.......please skip over my question.
#17 | |
i wanted the intercooler for peace of mind and also i know in the future i will be running a forged motor and will be running alot more boost.there are a couple of guys that have intercoolers so i guess i was steered a little bit.i do have to say,i agree with nate 4.6 if you have no intentions of running more than 8 to 10 psi the intercooler is not worth it especially when it cost 1500-1600 dollars.i am also sending my piping off to have powder coated.
ADVICE FOR GUYS WHO HAVE A BULLITT AND PLAN ON BOOSTING!!!! WHEN YOU BUY THE KIT,THEY DONOT TELL YOU THAT YOU HAVE TO CHANGE OUT THE WATER PUMP PULLEY BECAUSE ON THE BULLITT THE WATER PUMP PULLEY AND ALTERNATOR PULLEY ARE LARGER. SO TO MAKE A LONG STORY SHORT I HAD TO INSTALL REGULAR GT PULLIES.
2001 bullittmmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds. Last edited by dcrow; November 28th, 2007 at 10:19 PM. |
I Almost Forgot,thanks Guys For Your Comments,i Suggest To Everyone,if You Have The Know How, Install Everything Yourself,it Makes You Appreciate Your Car Alot More.
Just My .02 Cents!!!!!!!
Threads Similar to: Pics Of Installs
| some pics of my car | Blk01ponyGT | Pictures | 13 | July 15th, 2007 07:15 PM |
| Installs happening tommorow | flattusmaximus78 | 2005 - 2010 | 3 | February 15th, 2007 12:31 AM |
| Some New Pics | ShapeShifter | Pictures | 31 | January 13th, 2007 05:41 PM |
| New Pics | 00vabchgt | 99-04 | 6 | November 15th, 2006 09:20 AM |
| A Few Pics | HMUSN | Multimedia | 4 | November 12th, 2006 11:58 AM |
