Discussing Front end help in the 99-04 Forum. It's not really in the steering... It doesn't have any realy affect on ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
unstoppable @ speed of light
It's not really in the steering... It doesn't have any realy affect on my steering, but I can feel whatever it is through the steering wheel when I turn the wheel while moving forward.
I raised the a-arm and rotated the rotor by hand and tried my best to turn the wheel... Nothing happened...
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
#22 |
is there any oil/grease inside your wheel on the side the noise is coming from
#23 |
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
hmm.. maybe a linkage issue..
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
#24 | |
Only thing in the wheels is break dust...
#25 |
What piece? There isn't any stress marks or unusual bends in any of the parts... A while back someone said maybe a tierod end... I'm not sure which part that is, and what it's supposed to look like in good condition.
#26 |
19.83 @ 12mph
your tire rods look fine.
I'm not sure where in the linkage.. it "might" have an issue. hows you front sway bar look?
#27 |
Sway bar looks untouched...
I just noticed something. I think it's the exciter ring for the front ABS. It's looking bent when I rotate the rotor and look down on it. I don't see how that could be affectin the steering or making any noise though...
#28 |
19.83 @ 12mph
I don't see that scraping anything
#29 |
put it back together let it down...
try to move the tire side to said. this can indicate wheel bearing problems. try to rock the tire at the top. this can show ball joint problem. and go to an empty parking lot turn to lock at low speed back and forth. if it pops check you a-arm bushings.
#30 |
19.83 @ 12mph
^ good advise.
I'm telling ya.. it's only going to happen while bearing weight
#31 |
Me neither...
I don't have anyone here to help until this weekend. I'll have her turn the steering wheel while I rotate the wheel...
#32 | |
Thanks. I'm going to try that tonight.
#33 |
Here's a curveball for ya... While doing the stop to stop test I noticed that it only makes the noise while in gear. When I was doing those circles I would push the clutch in and the noise would go away...
Sounds like it's maybe in the rear end???
#34 |
you might be hearing your t-loc engaging and disengaging
drain the fluid over a screen and see if theres and metal or clutch material if not i wouldnt worry about it
#35 |
I just had the rearend rebuilt, with an Auburn 31 spline locker and 31 spline Moser axles... I didn't used to hear any noise for the first month or so when I had just gotten it rebuilt. Now it seems to be getting worse.
#36 |
19.83 @ 12mph
also pull the fill plug and check for shavings.
the plug had a magnet on it.
#37 |
The Cable Guy...
SLOW
If he pushes the clutch in and it stops my guess would be throw out bearing...
The rear end would still make the noise even if you pushed the clutch in if it was the rear end... |
#38 |
19.83 @ 12mph
that makes sense as well.
you car is demented. give it to me.
#39 |
But it only happenes when I'm turning to the right, and just a little when I hit the stop turning left. If I"m going in a straight line, say approaching a stop, and I push in the clutch, nothing changes. It's like normal healthy operatoin from everything...
#40 |
19.83 @ 12mph
it sounds like differential issues to me now..lol
Threads Similar to: Front end help
| front o/2's? | 04gtvert | 99-04 | 4 | October 18th, 2007 01:04 PM |
| Front-End | Stangzilla | 5.0 Mustangs | 44 | March 20th, 2007 07:34 PM |
| Cobra front? ROUSH Front? or Mach1 Chin? | Chris02 | 99-04 | 11 | November 19th, 2006 12:10 AM |
| Front End | ttop5.0 | All Other Vehicles | 0 | June 28th, 2006 09:03 PM |
| RYR front row | 89LX50 | The Clubhouse | 10 | October 4th, 2005 01:14 AM |
