Header Install Help
Old November 29th, 2007, 08:42 PM   #1
RC02GT's Avatar
2006 Saleen s/c
RC02GT is on a distinguished road
Send a message via AIM to RC02GT
Header Install Help
I planned on installing my headers this weekend and reading some install directions is discouraging me. Im not to excited about removing the engine mounts, dont want to mess something up, the steering shaft (dont want to mess that up either) and if i remove the k member will it go right back in place or will something shift? I think im in over my head on this one . I dont have a lift either so its all off jackstands, anyone had experience? Should I say screw it and just put the x pipe on? Its my only car to drive i cant afford to f something up.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune
Old November 29th, 2007, 09:24 PM   #2
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
i did mine in the drive way on jack stands, just takes time.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old November 29th, 2007, 09:32 PM   #3
RC02GT's Avatar
2006 Saleen s/c
When you took the k member off did it go back on easily? Someone told me something might shift a little?
Old November 29th, 2007, 09:57 PM   #4
13.7@101
mikeGTmurr46 is on a distinguished road
Send a message via AIM to mikeGTmurr46
Question
headers are definitely time consuming. The motor mounts may need a good amount of torque to come off but its not too big of a deal. Are you by chance doing long tubes?
Old November 29th, 2007, 10:28 PM   #5
RC02GT's Avatar
2006 Saleen s/c
no shorty, so that will help me a little. will I def. need to take the struts and springs off?
Old November 29th, 2007, 11:04 PM   #6
zerofx150's Avatar
2003 GT
13.6 @ 101
you would be suprized that it goes back on pretty straight, if anything get a paint pin and mark everything. Be carefull with the coil springs they are a little tricky and dangerous
Old November 30th, 2007, 05:06 AM   #7
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i didnt completely drop my k. i removed the motor mounts, and jacked the motor a little. the steering shaft will be fine as long and you dont get in the car and sit there turning the steering wheel. i did my long tubes on jack stands also. as for alignment, everything should go back in place with minimal changes.
Old November 30th, 2007, 10:27 AM   #8
stanginit's Avatar
stanginit is on a distinguished road
Its a lot easier than you think. You are psyching yourself out. Its just time consuming. The k-member will go back up into place. Without a lift and the proper tools...expect to spend a day or even two in the drive way. It took me about 8 hours to install my bbk lt's, bbk h-pipe, and flowmaster cat-back
'99 GT, BBK Long Tubes, BBK X-Pipe, Flowmaster Delta 40's Catback, Accufab 70mm TB, C&L Inlet Pipe and MAF, 3.73's, Eibach Pro-Kit, Tokico Ilumina 5-way Ajustables, Granetelli Upper and Lower Control Arms, 18" Chrome Bullets
Old December 3rd, 2007, 11:11 PM   #9
13.7@101
+1 on that. Just be thankful your not slipping a set of long tubes in there for the first time... That gave me hell
Threads Similar to: Header Install Help
Header Install zerofx150 99-04 24 October 9th, 2007 10:45 AM
header install nutterbutter 99-04 22 September 23rd, 2007 03:50 PM
header install superman5.0 5.0 Mustangs 15 June 30th, 2007 11:08 PM
header install dumps 2005 - 2010 8 May 18th, 2007 01:25 AM
Header install help lecherp 99-04 1 April 4th, 2007 03:18 AM
