Brake Issue
today i changed my rear brake calipers,both of them, an know i barley have brakes on the back,i have bleed them for over a hour trying to get them back,the brake paedal is to soft an only the front wheels lock up on it when applying hard.is there something i did worng,an i have already took them back an tried 2 new ones,im out of a clue here
did you turn the pistons in the caliper so they seated ?
Bleed your mastercylinder. There are 2 bleeder screws at the master, one for the front and one for the rear. Just bleed them both and you will fix your problem. Hope this helps.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
+1 the one everybody forgets lol
![]() 2004 GT Boosted by Vortech |
03 Mustang GT 91 bmw 525i
![]() ![]() iTrader: 2 reviews
is your abs light on? the locking up sounds like a problem i've experienced with fords when the abs system has a failure in it. for the no rear brakes, i'd try bleeding the master cylinder, if it doesnt work your most likely gonna have to replace it. if thats the problem it will cause the problem with locking. good luck man.
I just changed all my brakes and I am having the same problem. The pedal goes straight to the floor and no fluid or air comes out of the bleeder valves when I pump the brakes like there is no pressure.
Bleed the master!
what do you mean by seated
the rear brakes calipers have to have the pistons turned in to seat flush unlike regular calipers that are just pushed in with a brake tool/c clamp
In the Haynes manual it says that you can't bleed them at home if air gets in the HCU and that you need an expensive tool. Is this true?
nah.. you can bleed them at home.
you could use a ngs tester as well though. Mustang 1998+ ABS Diag Info
Thanks it worked perfectly
oh glad too see it worked out for ya
ok theres one easy way to prevent this especially if you are going to bleed the brakes anyways. i've found this only really works well on fords since there the only ones that have that problem alot, open the bleeder valve on the caliper when you compress the piston, than bleed the brakes like normal. sometimes with fords when you push in the piston without doing this, the inner seals of the master cylinder will be damaged and you will destroy it.
^ correct.
i bleed the master cylinder an now i have dam good brakes
yeah glad to see the brake pedal get stiffer
Threads Similar to: Brake Issue
| Brake Issue | xx9gt6xx | 99-04 | 7 | August 30th, 2007 05:35 PM |
| Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits | OcOnnor220 | Modular Mustangs | 2 | July 8th, 2007 01:36 AM |
| t5 issue | 342stroker | 5.0 Mustangs | 3 | June 4th, 2007 10:41 PM |
| Cobra brake or bullit brake upgrade | 97gtstang | 96-98 | 5 | May 14th, 2007 03:15 AM |
| Brake Light and Traction Control issue ? | wgmarq | V6 Mustangs | 2 | August 10th, 2006 09:54 PM |
