Rear End Question
Old December 4th, 2007, 12:26 AM   #1
Killax15 is on a distinguished road
Rear End Question
I PLan on putting 4.10 or 4.30 In my 2000 gt If i get this what else will i need? WHen it comes to getting a whole new rear end thats strong? thanks guys
MOTIVE GEAR Part # F88BI {Open Differential Internal Kit; Incl. Side And Pinion Gears/Washers/Pinion Shaft And Lock Bolt Or Roll Pin; 8.8 in.; 31 Spline; Large Pin;}
Rear 8.8 in. (10 Bolt), thats from a 2000 mustang cobra
Old December 4th, 2007, 01:16 AM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
A tune to make corrections.
360HP / 345TQ N/A
Old December 4th, 2007, 05:30 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
how strong you want? how much power will you end up putting down?
Old December 4th, 2007, 06:03 PM   #4
Umm my plan is to get like 450, but that part is pretty cheap it was like 120.00
Old December 4th, 2007, 08:33 PM   #5
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
if you can weld you can brace it yourself. one of the main problems with the rear end is the tubes turning, cracking and etc. cut em , notch the housing, and re weld them will help.
add bracing. rear end girdle. 31 spline axles and diff., c-clip eliminators.
FX4 Crew
Crew member #3
Old December 4th, 2007, 08:39 PM   #6
finaly03vert's Avatar
03 gt vert
lights cant time it
finaly03vert is on a distinguished road
where do u notch them just wondering i haven't looked in to this before
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods
Curently building up 03 mach block w stage 3 port job. look for twins and more n2o
Old December 4th, 2007, 08:42 PM   #7
mattstang's Avatar
top and bottom. front and back dont really have enough meat.
FX4 Crew
Crew member #3
Old December 5th, 2007, 06:37 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
450 is not that big of a deal. a set of good axles will be about the only thing that would be needed to run that without problems. a better diff wouldnt hurt, but not neccessary. 450 wont hurt the tubes, but then again it wont hurt to go have them welded up. you can go to a 31 spline set up if you wanted that much more reassurance. i did a 31 spline t-lok out of an exploder, and a set of alloy axles. they are flawless.
Threads Similar to: Rear End Question
rear end question.... 7-up man 5.0 Mustangs 27 September 23rd, 2007 12:49 AM
rear differential question rx1_ns 96-98 3 July 28th, 2007 03:09 AM
Rear end question Brute448 5.0 Mustangs 2 February 13th, 2007 01:06 PM
5 lug/ Lincoln rear end question dblack 5.0 Mustangs 2 January 3rd, 2007 08:28 PM
Question about Rear Gear 3.73 or 4.10 ? Xtra 2005 - 2010 8 December 31st, 2006 03:39 PM
