Rounded Off Nut, Can't Get It Off
Not a problem with the mustang... i'm doing a piston on my dirtbike 2001 CR250 and on the top end is a 14mm nut that holds it on. the nut is on there pretty damn tight and it's stripped on the outside tried using everything and the damn thing wont come off... any ideas???
-SEMPER FI- |
03 gt vert
lights cant time it
channel locks, big ass channel locks...? craftsman easy bolt out
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods Curently building up 03 mach block w stage 3 port job. look for twins and more n2o |
craftsman has an extractor.
if it is a beefy bolt. you tap it on with a hammer. and it has left hand tapered cutting threads you tighten and it tightens onto to bolt till its broke lose. your bolt may be aluminum. and never used it on that before. or you could try a monkey wrench
FX4 Crew
Crew member #3 |
02 Mustang GT
17.8@52
![]() iTrader: 1 reviews
gator lock sockets haha get them off of the home shopping network
heat the nut up
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
haven't tried and extractor. it's not a bolt... its a nut on a stud
-SEMPER FI- |
you could pull the stud and just go buy a new one.
FX4 Crew
Crew member #3 |
03 gt vert
lights cant time it
if there r enough threads on the stud try to thread another nut down on it with locktite then use it to remove the stud ?
x2 heat it up with a propane torch and it should pop lose easier.
4.6 2V PI HEADS,PI CAMS,COMP SPRINGS,PI INTAKE,03 COBRA CRANK,PISTONS,5140 S/F RODS, VORTECH S TRIM 6/9PSI 3.73 60 LBS INJECTORS,90 MM MAF, SCT CUSTOM TUNE. ![]()
that will work...
FX4 Crew
Crew member #3 |
i wouldn't heat up that aluminum, it's soft. get a hammer and a good chisle and start hittin it .
www.hsvracing.com |
pipe wrench
it would work if its a steel bolt in aluminum. but its most likely a steel bolt on steel stud in aluminum. and he cant get enough bite on it to back the stud out
FX4 Crew
Crew member #3 |
FX4 Crew
Crew member #3 |
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
take a picture of your nut
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
cut the nut with a dremmel tool.
same as messed up exhaust nut, tap it off with a chisle and hammer
www.hsvracing.com |
03 gt vert
lights cant time it
-SEMPER FI- |
there's not too much room in there to tap on it. i'm gonna try heating it up, hoprfully that works...
-SEMPER FI- |
