White Face Gauge Install
Old December 5th, 2007, 12:19 PM   #1
2003 Mustang GT
Silver6 is on a distinguished road
Okay guys, I searched the forum before I started this and most of the posts I found had to do with how the gauges looked so I'm going to ahead and ask my question.
I ordered white face reverse glow gauges from American Muscle and am curious as to whether or not I can install them myself. So, I'm looking for anyone who has done the install and can give me an opinion on difficulty and whether or not the needles have to come off.
Your help is greatly appreciated!
Old December 5th, 2007, 12:33 PM   #2
OhhShorty's Avatar
1995 Mustang GT Vert
OhhShorty is on a distinguished road
Send a message via AIM to OhhShorty Send a message via MSN to OhhShorty Send a message via Yahoo to OhhShorty
i ordered the Silver reverse glow gauges from American Muscle as well and they have an install page on thurr.. i printed mine off and it tells you exactly how to do it.. jus go back to the page that you ordered the kit on and it'll have it at the bottom of the page
"For I have made mistakes, which made me a better man, I will forever believe that you can live with NoRegretz"
'95 5.0L Vert
www.wotmustang.com
MILITARY CREW
E-5
Old December 5th, 2007, 02:11 PM   #3
2003 Mustang GT
Did you find that it was difficult to do the install yourself?
Old December 5th, 2007, 04:25 PM   #4
Proud American
MustangMatt96GT's Avatar
Mustangworld White face gauge kit Install
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old December 5th, 2007, 04:49 PM   #5
jrfan4life's Avatar
2001 Mustang GT
NA
jrfan4life is on a distinguished road
I installed the exact same guages in my car and on a difficulty level i would rate it a 6 out of 10.... You need torx heads to remove the guage cluster first of all.... remove the 2 in the underside of the dash board to remove the plastic bezzel.... then take out the 4 screws that attach the cluster to the car.... slide the cluster forward with the steering wheel tilted as far down as possible... then unplug the 2 sets of wires and remove the cluster from the car.... Go inside and sit at your table and continue on... Remove the 10 screws with the torx head remove the plastic bezzel.... now take the insert they give you and carefully slide it over the needles... DO NOT REMOVE THE NEEDLES!!!!! ..... This is going to take some time because you have to get it over the needles and the locating pins in the cluster. ok... now that you have in on.... the part they dont tell you in the directions.... you have to make sure the pannel is centerd exactly over the cluster.... if not when you light up the guages the lights dont line up with the idiot lights on the bottom. So....center the incert around all the needles and tape it in place so it does not move when your reinstalling the clear bezzel...so....put the clear bezzel back on then procede back to the car.... Now...I spliced mine into the light switch I believe the secont thick wire from the front of the switch... I cant remember the collor... this way... when you have the parking lights on the needles glow red... then when you have the headlights on everything glows... then I grounded right to the 3 inch round pipe that runs threw the dashboard with a teck screw....Install everything back in the dash and you are ready to go.... hope this helps...
Old December 5th, 2007, 05:29 PM   #6
RC02GT's Avatar
2006 Saleen s/c
RC02GT is on a distinguished road
Send a message via AIM to RC02GT
I did my roush gauges not to long ago, easy install im sure you can handle it.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune
Old December 7th, 2007, 03:38 PM   #7
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
nothing to it,some dont require taking the needles off,mine didnt an it was a breeze
Old December 7th, 2007, 04:52 PM   #8
2002 mustang GT
13.2 @104mph
hotshot is on a distinguished road
I did some for a friend in an 02 ranger and it wasn't difficult at all.The only thing I can add is if you have to remove the needles a fork works better than the lil tool they give you and remember to TAKE A PIC OF THE NEEDLES BEFORE YOU REMOVE THEM or you will be wondering if they are accurate forever.
02 GT.
04 Z1000 (hooligan machine)
04 gsxr 600
98 GTP
Threads Similar to: White Face Gauge Install
White Face Gauge Conversion?? Speedstang302 5.0 Mustangs 3 September 9th, 2007 11:22 PM
White face gauge install energiesource 99-04 9 July 25th, 2007 03:59 PM
Fuel guage stuck after white face guage install r7r5 94-95 1 March 2nd, 2007 09:35 AM
White Face Gauge Install jerb43 Audio/Video 3 October 19th, 2006 05:31 PM
