Make My Shopping List
Old December 5th, 2007, 09:02 PM   #1
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Alright for those of you that are bored and know anything about nitrous setups here's your chance to become unbored for a little while. I know very little about setting up a nitrous kit so pretend I'm car retarded. I don't know if it makes a difference that I have a 4V motor and not a 2V. Here's what I want:
100 wet shot or less (much more than that will put me closer to 450 than I want to be)
I want to manually engage the nitrous, but I also want safety systems incase someone in the passenger seat gets the I want to push the button sickness. So I know I'll want something with WOT and most likely a window switch that will control nitrous spray through rev limits and gears.
Purge kit
Heater
Anything else I might not be thinking of.
Alright toss down the hyperlinks.
Also, will I need a separate tune (notice I have an XCal3) or is there a way that I can set it so that a tune kicks in when the nitrous is engaged?
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old December 5th, 2007, 09:11 PM   #2
RC02GT's Avatar
2006 Saleen s/c
RC02GT is on a distinguished road
Send a message via AIM to RC02GT
did you ever decide on your driveshaft?
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune
Old December 5th, 2007, 09:18 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
only way to change tune on the fly is a flip chip. it the car is tuned, the timing will have to be taken back to stock and modified from there. n2o kits come with a WOT switch. the n2o wont engage until its is in WOT. then there is a window switch to help when to turn the spray on and off ant certain rpms. you will need to run a 1 stage colder plug when you go the the spray too. you can hook a push button in line with the arming switch if you want one. heater, purge, fpss, are a few supporting mods that are highly recommended. and a blow down tube wouldnt hurt to have either.
Old December 5th, 2007, 10:13 PM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I'll probably go with an aluminum shaft and a throttle body. I may just save my money though. Things tend to go wrong and it's always after I've made a purchase of a few hundred or more.
Do I need to just go with a 4.6 motor kit or is there a difference between 2 and 4V?
Old December 5th, 2007, 10:37 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
No. any 4.6 mustang kit will work. I run my 100 wet shot on stock timing, and it works great. I have ngk tr6 plugs and it hits from 2200-5800 rpm. i use the msd digital rpm window switch. you can run a hundred shot with just the plugs and stock timing. If you are worried about it then just set your tune back to stock and drop a degree out.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 5th, 2007, 10:41 PM   #6
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Ok here's a situation. Say you're on the street and wanna run nitrous but you didn't have your car ready for it, but you did have the heater on. Am I SOL? Or can I spray and not have to worry about anything?
Old December 5th, 2007, 10:57 PM   #7
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
If you are running alot of timing (I assume you are) and you hit that 100 shot it will most likely spell disaster for the motor. my advice would be to setup 2 tunes (since the xcal will hold 2 or 3) and if you want to "hunt" or "play" put in the nitrous tune, if you are daily driving, run the motor tune. Unfortunatly without the flip chip you can't have the best of both.
Military Crew
U.S. Army Aviation
Old December 5th, 2007, 11:01 PM   #8
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
That's the thing. I don't hunt. I usually just happen to come across someone when I least expect it.
Old December 5th, 2007, 11:14 PM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
one or the other with a programmer. cant sprtay on top of an all motor tune, too much timing. you will loose all motor power if you just run a nitrous tune. there are sacrifices to doing this stuff, just depends on what all you want.
Old December 5th, 2007, 11:23 PM   #10
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Drop the dough on a flip chip then. or sacrifice the timming and have the bottle on tap whenever you want it. If you go that route though I would bump it back a degree or 2 and run close to a 130 or 150 shot.
Military Crew
U.S. Army Aviation
Old December 6th, 2007, 04:53 AM   #11
2003 Cobra
Bigmac is on a distinguished road
Send a message via AIM to Bigmac
get a remote bottle opener for the nos kit
509RWHP/507RWTQ
Black Stiegy Stage IV ported blower, ported plenum, ported TB, Steeda intake, Magnaflow X-pipes with Magnapack catback, BF 2.93 upper with 4 idlers, 4lb. lower, 3.2 alternator pulley, MAFia, Boost-a-pump, Centerforce DFX clutch
Old December 6th, 2007, 07:27 AM   #12
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
who ever said anything about getting nos?
Old December 6th, 2007, 08:19 AM   #13
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
+1 Don't get NOS if you want everthing to work properly
Military Crew
U.S. Army Aviation
Old December 6th, 2007, 08:23 PM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
another person that calls nirtous f*ckin nos. i hate that shit!!!
Old December 6th, 2007, 08:35 PM   #15
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
why not have a nossss tune in you programmer with your n/a tune???
nos=short for nitrous
*wait for sweet2k's head to explode*
no really i hate that as well. i just refer to it as the bottle or nitrous. when typing n2o
FX4 Crew
Crew member #3
Old December 6th, 2007, 08:53 PM   #16
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
*BOOM* its not hard to type nitrous, n2o, giggle gas, juice, spray, the bottle, etc.
Old December 7th, 2007, 12:42 AM   #17
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I know I could do that but could I change the tune on the fly, or do I need to shut down the engine and that stuff?
Old December 7th, 2007, 02:23 AM   #18
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
eliminator/flip chip can be done on the fly. a tuner you will have to shut off the car, and load tune. but if you change something that requires to change the tune, you will have to have the chip reburned. the tuner, you can just make the adjustments that are needed.
Old December 7th, 2007, 07:58 AM   #19
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
The flip chips are the only way to load tunes on the fly. The programmer lets u change the parameters of the tune when ever you want, but if you want to be able to change tune, activate the N20 and race on the fly, the flip chip is the only way. But like sweet said if you want to change parameters in the flip chip it has to get re-burned.
Military Crew
U.S. Army Aviation
Threads Similar to: Make My Shopping List
can someone help on photo shopping? 86ttops The Clubhouse 3 October 8th, 2007 12:52 AM
doin some shopping...help? allpaidfor V6 Mustangs 3 February 22nd, 2007 04:24 PM
Let's Make A List For The GT! Some Terminator Killing To Do Chris02 99-04 56 November 24th, 2006 09:28 PM
Finally Finished My Shopping List... Tell Me What You Think Aeroz V6 Mustangs 10 September 8th, 2006 06:51 PM
