mid pipe leak
i have a mac h pipe and it leaks like a bitch do i lose power from that and wat can i do to fix it like bolts or anything
Is yours leaking around the driver side manifold flange....IF thats the case mine is aswell there is a little shoulder on one of the bolts and it prevents it from comming down all the way to seal up properly. My mac h did and now my mac x does that, I need to replace all the studs to see if that will fix it, also there is a reducer that should have come with the pipe, make sure that is in the driver side pipe it helps alot.
01 Mustang GT | 5 Speed | Bullitt Intake | 4.10's | Diablo Tuner | JLT CAI | Flowtech LT Headers, bbk catted H, dynomax catback | 01 Carbon Black BMW M3 w/dynomax exhaust
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
if its around the drivers side flange and its on stock manifolds, you must use the adapter they send. had the same problem on my friends mach, slipped in the little adapter and leak fixed.
Threads Similar to: mid pipe leak
| H - Pipe Or X - Pipe With Cats? Which Brand For Price? | dave07GT | 2005 - 2010 | 13 | December 11th, 2007 11:59 AM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 04:46 PM |
| mid pipe leak | o3gtdgs | 99-04 | 9 | October 20th, 2006 01:42 PM |
