Discussing Slotted Or Drilled Or Both? in the 99-04 Forum. I dont plan on seeing track times anytime soon. I dont accelerate and stop at ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Ford Mach
Traveling at the speed of a photon
![]() Under my Umbrella! Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. |
2006 Mustang GT
12.85 @ 104.85mph before 4.10's
what exactly do Stainless Steel brakelines do performance wise??
![]() BBK LT Headers w/ o/r x pipe : JLT CAI : 93 octane tune : Flowmasters : Hurst Shifter : Steeda Lower & Upper arms : 325/45r17 M&H's for the track : CHE K-Member/Torque Limiter : FRPP 4.10's : Steeda UDP's Hurst Crew Member #3 Co-Founder |
2003 Ford Mach
"Due to the high stress and temperatures of racing these hoses are considered a safety requirement for all vehicles which are raced since the high heat generated during track use may cause failure of the stock rubber hoses"
I know this states its for racing but over at the registry and some people with gts have claimed an improvement in braking. Firm, and hard! more reliable too.
More specifically, steel braided brake hoses give you a firmer pedal because there is less hose bulge or flexing under (racing) hard braking conditions. I installed them on my car.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
To answer the original question, probably not.
latest tune: 370 rwhp/377 rwtq Garage: http://www.moddedmustangs.com/forums...-member-11329/ Previously Owned: 1966 Coronet 500, 426 ci/4 speed, est. 290-300 rwhp 1969 Camaro SS, 350 ci/4 speed, est. 210-220 rwhp |
2002 Chevrolet Impala
#7 | |
2003 GT
#2 - See #1 #3 - Drilled rotors have had a tendency to crack but it really depends on the heat cycles you run the rotors through. #4 - As far as gaining any real amount of performance or better stopping, no! Drilled rotors are meant to dissipate heat away from the rotor but some have said that drilling also takes away valuable surface area that can be used for braking performance. I doubt you will get your brakes hot enough on the street to have cross dirlled and slotted rotors make that much of a difference. John |
But my oversized cross drilled and slotted rotors look very cool on my car...
Threads Similar to: Slotted Or Drilled Or Both?
| Slotted vs Drilled | TheBusher | 99-04 | 23 | November 13th, 2007 12:08 AM |
| Wher can i get resonable sloted an drilled rotors and brakes | blown96stang | V6 Mustangs | 15 | June 2nd, 2007 03:09 AM |
| Front and rear slotted and cross drilled rotors for '96-'98 | starman1950 | For Sale | 0 | January 17th, 2007 12:54 AM |
| Slotted and Drilled Rotors | blue05GT | 2005+ | 2 | December 10th, 2006 01:44 PM |
