Front Suspension
How hard is it to install a k member. I want to use MM K member and MM front A arms. Can i use A arms just on stock suspension or is that worthless? I already have C/C plates and order control arms for rear but want to get front suspension does as well so any sugestions would be nice.
2001 mustang gt 5 speed Full bolt ons with 4.10 gears. 1965 Mustang 302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter. In the process of restoring it... |
2003 GT
K member is probably one of the more difficult components to put in but only because it requires 2 guys to put it in. It's not hard, per se, just time consuming getting everything lined up. When I installed mine I had to hog out the bolt holes they had since it didn't line up with the frame rail holes. You'll also need to lift the engine up a little so that you can get the motor mounts back on.
Don't use the stock A-arms! Just use the MM ones. You'll be glad you did! I don't even think you can use the stock ones although I didn't even try on my installation so maybe you can but why? I would add the MM Bumpsteer kit to complete the front suspension along with the rack relocator kit. Not much more money but makes driving WAAAAYY more enjoyable! For rear I would add the adjustable sway and PHB. The Torque Arm you can add later but those other two things will also vastly improve the handling of your car. John |
Threads Similar to: Front Suspension
| front suspension | whiteboycustom | 5.0 Mustangs | 26 | February 1st, 2012 11:38 AM |
| 65 Front Suspension? | Spiderz | Classic Mustangs | 11 | July 24th, 2007 04:39 PM |
| Noisy front suspension | stanglover99 | General Tech | 1 | July 18th, 2007 03:56 AM |
| Front End Suspension Install... HELP. | 88BlueGT | 5.0 Mustangs | 7 | February 28th, 2007 08:42 PM |
| FR500 front suspension | banini | Modular Mustangs | 0 | September 25th, 2006 02:39 PM |
