Fox Lake Custom Grind Cams
Old December 7th, 2007, 11:43 AM   #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
Ive been emailing a guy from Foxlake performance about getting some heads and cams. Well atleast i think it the guy from foxlake. His email name is cncfast@hughes.net. He says that he has the same vt stage 2 heads that vt were selling and he can custom grind some aggressive stage 2 cams for me. I was wondering if this would be a good set up. Would the custom grind cams bring me more hp?
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old December 8th, 2007, 08:36 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
head work is a great mod. anything that is custom tailored to your set up will always be best and get best power. the negative is, if you do dramatic changes, so will a set of custom grind cams.
Old December 8th, 2007, 09:21 AM   #3
1965 Ford Mustang
The heads and cams are going to be the last mod i do that is this large. I will still be puting headers, suspension, and gauges in but nothing to the engine. After a while with the cams and heads, ill probably get forged internals
1965 Mustang
Threads Similar to: Fox Lake Custom Grind Cams
3rd Gear Grind? PonyXpress 5.0 Mustangs 1 December 14th, 2007 01:42 AM
3rd Gear Grind? PonyXpress 99-04 5 December 5th, 2007 12:44 AM
96GT T-45 1st-2nd Grind... Help! KaskaB 96-98 4 November 12th, 2007 02:18 PM
Custom Cams and power adders ghostdog 2005 - 2010 12 December 26th, 2006 02:15 AM
grind when shifting in to 3rd and 4th macnesa23 5.0 Mustangs 1 September 1st, 2006 10:14 PM
