Rebuild/Bore Out 4.6 Or Supercharge It?
Old December 13th, 2007, 12:24 AM   #1
1999 Mustang Gt
0di3 is on a distinguished road
Send a message via AIM to 0di3
I have a 99 gt with some tasteful engine mods. I got the car with 107XXX and it has 111XXX on it now. My question is pretty easy. should i rebuild and bore out the engine adding some power (also what do you think this would cost and what heads should i get?) or get a vortech supercharger kit and run it with around 6-7 psi
let me know your thoughts
Old December 13th, 2007, 12:48 AM   #2
strkrstng2000 is an unknown quantity at this point
If you are adding displacement and boost go with the highest flowing head you can find. I stroked mine and am planning on boost. I chose patriot stage 3 heads. If you are not adding boost stick with a stage 2 head. I love the power band on my stroker but it does need boost especially with the stage 3 heads. If you do go with a stroker (with no plans for boost) go highest compression you can run on pump gas and spray the hell out of it. The cost on my rebuild was expensive but I also purchased heads and cams along with a full forged and balanced stroker kit. Parts alone were over 5k all said and done. I upgraded other things too such as intake, injectors, new maf, ect... I had to rebuild mine because I had spun 3 bearings and had 2 rods knocking. For the money I could have had the baddest sc out there (motor would not have supported it). It is all in what you want, I want 800 to 1000 hp with a big turbo. Those are my goals, those are not most people's goals. If you want a 400 rwhp car and will be happy with that go sc, if you want more rebuild and save for a power adder.
Old December 13th, 2007, 08:52 AM   #3
gsjohnson is on a distinguished road
+1...
I would definitely rebuild the motor first keeping in mind that my next mod would be to add boost.
The difference between a girlfriend and wife is about 50 pounds.
Old December 13th, 2007, 09:11 AM   #4
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
Just rebuilt forged high compression and spray the shit out it, it will be 100 times more fun the boost.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old December 13th, 2007, 10:57 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
You will have to rebuild if you s/c anyway, so you might as well budget that for starters. If you want boost get dished pistons, if you don't want boost get flat tops. It is gonna cost the same for pistons, h-beams, and a good crank no matter if you go n/a or s/c. So, you need to decide your power goals first and foremost. good rotating assembly is gonna put you out around $1k depending on what setup you want. The thing to remember is if you are going to run FI and you build the internals to handle boost, your are not going to be making much N/A power while you wait on your power adder. If you decide to go bottle fed, get the highest compression you can and some good heads and cams.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Threads Similar to: Rebuild/Bore Out 4.6 Or Supercharge It?
head bore? sniperrider 5.0 Mustangs 4 June 4th, 2007 05:01 PM
bore?? pistons "| 01stanggt Modular Mustangs 10 May 19th, 2007 07:42 PM
302ci bore to 347. stang94 94-95 2 March 21st, 2007 03:41 PM
stock bore Stock 5.0 Mustangs 1 January 7th, 2007 12:56 AM
Bore Size cali 5.0 Modular Mustangs 8 November 1st, 2006 02:00 AM
