mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
Sounds Like I Have A Damn Bird Under The Hood
i had the car down while i waited for my trans to get here a couple months back. everything ran fine when i shut it down, but after i installed the new trans i now have a noisy chirp under the hood. it sounds like a really bad belt squeaking, i took the belt off and eliminated that possibility. after looking some more, it is coming from the top end in the back behind the plenum. it does it when the car is creating most vacum like when it is on its way down the rpm band. it does it no matter if its idling or if i am driving, cold or hot, etc. i have a new intake manifold to put on, but would like to fix the problem before i do anything. anyone ever heard or had anny issues with something like this. i just got another key made for it today, so i will drive it a little bit while i do a little work on my truck.
2002 Chevrolet Impala
I had a similar problem when I installed my CAI, TB, & Plenum. While I was installing my CAI my buddy attached my TB to the Plenum. About two weeks later three of the four bolts fell out that were holding the TB on. I got a horrid squeeking noise becuase there was a tiny air leak. It only did it at idle of cruize. If I were at light to WOT, the sound went away. Fortunately for me, all three bolts landed on my intake manifold and stayed there until I found them and put them back in. Maybe you have a bit of an air leak somewhere like I did
Saving up for another one
that sounds weird man. i dont know what to tell u. ive never seen that.
mm's nitrous mod
2000 mustang gt
i dont have much time any more to mess with little shit like this any more. i was just wondering if any one had similar issues. i guess i will have to search and waste time on it that i dont have.
x2
mm's nitrous mod
2000 mustang gt
i think i may have a cracked intake manifold. sounds like its from the passenger side, but i cant see a crack, messed up vacum line, or anything. the sound is decieving, and might be coming from the lower part of it.
Proud American
you wont see a crack in the manifold, they are almost impossible to see
mm's nitrous mod
2000 mustang gt
i changed the intake manifold to day and the chirping went away. i guess i had a crack in it. i will look for one or test is within the next couple days. i had an intake with the aluminum x-over that i decided to go ahead and install. i opened up the ports before i installed it, but now i have to make a new alternator bracket for it.
Proud American
I dont have an alinator bracket on my car!
mm's nitrous mod
2000 mustang gt
after i started my car the belt decided to to start shreding. it shreded the 2 ribs right off the start. i am just making one out of aluminum here at work.
Proud American
well if thats the case, good idea. You want to make me one too?
mm's nitrous mod
2000 mustang gt
i can, i just use whatever scrap metal we have here at work. usually dont have anything to do most of the night, i can knock one out pretty quick.
Proud American
if you want, ill pay shipping for it.
2001 YUGO GT
Get a spray bottle and mist water around your manifold when the engine stumbles you have found the source of you leak. Back in the day WD40 was used what an F-n mess!
mm's nitrous mod
2000 mustang gt
i did it with brake cleaner, that is how i always found vacum leaks. the whole top of the engine was covered and still did it. i just changed the intake out and no more chirping.
mm's nitrous mod
2000 mustang gt
i still had a little chirp after replacing the intak, but thought it was the belt since it decided to tear off 2 ribs. i replaced the belt this morning, but still have the damn chirp. it is not as bad as it was before, but is starting to really piss me off! anyone else with an idea on a possible problem?
Threads Similar to: Sounds Like I Have A Damn Bird Under The Hood
| T-Bird | MustangMatt96GT | The Clubhouse | 13 | November 1st, 2007 07:00 PM |
| Me vs a t-bird sc | ByPopularDemand | Drag | 19 | September 22nd, 2007 03:51 PM |
| Damn this sounds good | 06RedfireGT | The Clubhouse | 74 | August 29th, 2007 04:06 AM |
| A bird shit in my car | Juggalo_X | The Clubhouse | 24 | May 19th, 2007 05:18 AM |
| t-bird | terribleonexx88 | 5.0 Mustangs | 5 | January 3rd, 2007 01:54 AM |
