2000 mustang gt
Shift Light
ok i am trying to install a shift light in my 2000 gt and its kicking my butt. i did the power ground and the orange wire with a white stripe on the p/s kick pannel. what am i doing wrong?
2000 mustang gt
summit. the one with the dial in the back
2000 mustang gt
yes i think so. if the tech lead is the orange wire with the white strip in the passinger side kick pannel
2000 mustang gt
i dont have one but i really should buy one. just wondering if anyone on here has done one before.
Don't buy a haynes manual for electrical. The manual will not show anything for wiring. Go to your local dealer and ask for pcm wiring. I think the tach pickup is pin 87. Also you are going to need a tach adapter to install between the tach wire and computer. Depending on where you go, its abut 75 to 100 dollars.
1988 Mustang LX Turbo
Passenger side of car locate the power distribution box.
Unsnap top half of Power distribution box. Find under the GREEN box port C5. (2 larger solid red wires coming out of same port). Do not use smaller solid red wires. (Do Not use F6). Follow wires out a few inches and cut both. Twist together the 2 RED wires coming out of the power distribution box then hook them to the RED wire coming from the 9117 tach adapter. Then twist the remaining 2 RED wire ends from the wire harness together and hook them to the RED w/Green stripe wire from the 9117 tach adapter. The GRAY wire from the 9117 tach adapter hooks to the GREEN wire on the 5310 RPM Module. The RED wire from the 5310 rpm module goes to power. The BLACK wire from the 5310 rpm module goes to ground. The Green wire hooked to the GRAY wire on the tack adapter.(tach signal). Plug in 5331 lite to the RPM Module.
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. Last edited by TurboLX; December 22nd, 2007 at 03:41 PM. |
Threads Similar to: Shift Light
| Best Shift Light | JaxnsGT | 99-04 | 16 | November 25th, 2007 08:13 PM |
| Shift Light Help? | JONJON | 5.0 Mustangs | 7 | November 11th, 2007 06:39 PM |
| Shift light? | JONJON | 5.0 Mustangs | 0 | October 18th, 2007 11:56 PM |
| what shift light for my z28 ? | GTblackprodigy | The Clubhouse | 8 | September 26th, 2007 04:30 PM |
| Shift light | travis_afx | 99-04 | 18 | June 19th, 2007 09:13 AM |
