Nitrous Question!
Old December 15th, 2007, 01:45 PM   #1
matthundley's Avatar
2002
matthundley is on a distinguished road
Nitrous Question!
I am looking into putting some nitrous on my 02 gt. Its pretty much stock except for CAI and exhaust. I am thinking of a 100 shot of dry by dynotune. and a purge kit. Is there anything else i absolutely need? How does the activation work without a tps, just flip switch and it comes on ? Thanks in advance. any help on this subject is greatly appreciated.
Old December 15th, 2007, 02:23 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
First off you need to get a tuner or a timing adjuster so you can bump timing back a little for the 100hp shot to be safe. Next you need to get colder heat range plugs. I personaly do not run dry kits on n/a motors. With a big dry shot you will be putting more work on the injectors. If you want the best performance from your kit you will want a bottle heater. Then to be safe you will want a window switch so you don't spray too early or too late(i.e. spraying into rev limiter). Most likely they will send a micro switch to mount on the throttle linkage, this will be your WOT activation switch. If they dont send one then yes most likely it will be a push button setup. I would stronly suggest you rethink a couple things. 1. get a wet kit. 2. get a kit that comes with either a tps switch or a micro switch. 3. DEFINATLY get a tuner if you are gonna run a dry kit so you can data log and see what the motor is doing. 4. If you are not gonna bump the timing back then start at a 75 shot and make sure it will take it then work your way up. 5. Never run anything below 91 when you are going to be using the bottle.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 15th, 2007, 02:44 PM   #3
2002
thanks alot !
Old December 15th, 2007, 03:13 PM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
all that is recommended, and a pressure guage to monitor bottle pressure. a purge kit will ensure that there is no air in the lines. dry kits are just as safe as wet, but i too am partial to a wet kit. if you do go with a dry, it would be a good idea to take it to a dyno and see the fuel system is keeping up. anything more than a 100 shot will need a fuel pump to be safe, and if dry maybe injectors.
Old December 15th, 2007, 03:56 PM   #5
2004 GT
slow....
pa.ulB is on a distinguished road
Send a message via AIM to pa.ulB
^thats about all you'll need,
2004 Crimson red GT
saleen s/c, full bolt ons
Old December 16th, 2007, 11:05 PM   #6
2002
thanks
Threads Similar to: Nitrous Question!
Nitrous question 89LX347 5.0 Mustangs 25 July 2nd, 2007 01:19 PM
I need some help (Nitrous jet question) acmillr 99-04 17 June 24th, 2007 11:46 AM
nitrous question fastlane_24 94-95 1 June 12th, 2007 09:42 PM
nitrous question justinsstang V6 Mustangs 18 May 7th, 2007 07:17 PM
Another nitrous question ByPopularDemand V6 Mustangs 24 April 13th, 2007 01:29 AM
