Heads vs Eaton Supercharger
Before i buy the after market parts for my car i want to know what you guys think would be better. I dont want to mess with the internals so thats why im thinking of the eaton supercharger, but would a good set of heads be better. I know theirs different kinds of heads but i dont really know of any for a cobra. Doest the eaton just bolt on the the cobra's engine or do i need some sort of adapter.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
all heads are ford heads, there are no aftermarket company producing their own cast yet. head work is a real good investment, it really depends on what your goal is. an eaton will bolt right up as long as you have all the stuff. the lower manifold is about the hardest thing to get without going to the stealership.
Gun Whore
04 Whipple Cobra
10.61@129.96
well with heads, cams, and a ported intake manifold, you can make some decent power on a NA 4.6DOHC. around 400RWHP.
i would buy revised feb. 05 heads, port them, and throw the FR500 valvetrain package on there, along with a ported intake, and full exhaust. only problem is it gets expensive. the eaton is a good option, but on a 99, it turns it into a ticking time bomb. those rods in there are really weak, and do not like boost. i would personally pull the motor apart, and spend that $$ in the bottom end. keep the stock crank, get some 03/04 cobra rods, they can be had used for about 300 or so. and go .020 over, and run some CP pistons, and you have yourself a GREAT bottom end. assemble it back with some ARP studs, and the stock heads, and all, and when you get the $$, its ready for a blower. |
#4 | |
mm's nitrous mod
2000 mustang gt
cant spend too much money on it, mom wont let me.
so i was hopeing the eaton with full bolt ons would give me enough.(wouldnt it be around 450 hp?)
#6 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
check out the new edge section on SVTperformance.com. they will say the same exact thing.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
#7 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
it will cost you about 3-4K to do it completely though, and that is no installation. parts are pretty easy to get now, with all the 03/04 guys going turbo.
99 limited edition vert
I think you would enjoy the eaton route more than heads.the butt-o-meter will love you for it
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
mm's nitrous mod
2000 mustang gt
i agree ford could of done better with the build on these cars, but they are plenty capable of making power. these motors will hold up to more than what most people will throw at them.
Boost gets you laid
throw a heaton on that thing. you can probably find one on ebay with <1000 miles on it for cheap.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
whats a good price to get for the eaton? dont know much about them.
Gun Whore
04 Whipple Cobra
10.61@129.96
you can pick up the blower itself for $400 or so. but you need a TON more stuff, including the following, and more:
eaton throttle body plenum intercooler lower intake manifold all the IC lines heat exchanger intercooler pump bunch of hoses cross over tube 03/04 EGR, or EGR delete (wont pass emmisions) 03/04 front engine cover pulley bridge assembly lower pulley cage 03/04 altenator 03/04 altenator bracket injectors fuel system and a BUNCH of other stuff. and at the end of the day, you have a inneficient roots style blower that blows 8PSI of hot air. you can easily spend a few more bucks, or less if buy used, and get a vortech, or procharger, which is 20X better of a blower, and the kit is MADE for your car. whole lot less labor, no finding parts. and about the same price. do the centrifugal.
1990 GT
just get a blower made for your car. why is that so hard. why does everyone think they can just slap a eaton on there car cause its a 4v. not to mention the eaton sucks. sorry to be a dick but if it was that easy everyone would have a eaton on there car since there are so many cheap ones for sale on ebay.
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
okay thanks for the advice, i guess ill have to save some more money
#16 | |
mm's nitrous mod
2000 mustang gt
#17 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
that is too much of a open ended comment. a VORTECH, or PROCHARGER, or PAXTON kit for a 99-01 cobra is a DIRECT BOLT ON for his car, a direct bolt on, and a "swap" are not the same thing. how many eatons have you installed on 99-01 cobra's? yes, for 3-4K he can have all the stuff to install it on his car, but then he has a eaton that blows 8PSI of hot air. he can make much more power, and do it safer with a centri, with the same boost level. and is just a little more. the eaton SUCKS.
#18 | |
mm's nitrous mod
2000 mustang gt
8psi of hot air??? not really, the air is not hot at 8psi. it is not the most effcient delivery, but it is not hot! safer? if it was not safe, there would not be any way that ford would of gave any warranty from the factory. it is when you start pushing a head unit past their VE, that starts to get really hard on the air. the eatons efficientcy isnt the greatest, but does a decent job. for those that just want the little extra, it is a great easy way to get what they want. hell, the heat exchangers stock do a very well job and will effciently cool a pretty high psi and volume. you want to call me out and go head to head with general or boost knowledge, step on up! you ask me in another topic how you call people out, you think you can come in here and just tell everyone how it is. no one knows everything, and everyone has their own opinion.
putting an eaton is just idiotic, when u can put something on bigger for a bit more money and LESS time waiting to find individual parts at low costs. lets not forget we are also talking about a NEW procharger/centri kit compared to a used eaton scavenger hunt. dont mind it being used? fine thats when u get a used centri.
99blkcobra im not trying to be rude if i was i apologize
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
1990 GT
if you want to spend 3-4 grand piecing together a shitty swap go right ahead. why do you think cobra owners get rid of that blower so quick. its not just as easy as bolting on the eaton, which is what it sounded like he was thinking. but its your money do what you want with it
Threads Similar to: Heads vs Eaton Supercharger
| 03-04 Cobra Eaton Supercharger on your 2V | White99stang | 99-04 | 119 | October 28th, 2010 03:11 AM |
| Eaton M90 Supercharger | 2002stang | V6 Mustangs | 4 | October 10th, 2007 04:05 PM |
| Eaton Supercharger | donny82277 | General Tech | 1 | February 24th, 2007 01:13 PM |
| “Eaton M-90 Supercharger” | shadowalchemistz | V6 Mustangs | 20 | November 26th, 2006 03:49 PM |
| Will An Eaton M112 Supercharger Fit On My GT? | phisherize | 99-04 | 6 | November 16th, 2006 05:54 AM |
