1999 COBRA
Search Is No Help For My Question
well i was unsuuccesful in finding an answer to this question using search. i think this is a common problem with 99 fords with the digital odometer, because i remember it on a 99 f150 i test drove once. ok so the problem is the odometer just cuts out from time to time for what seems like no reason. and then again for no reason it comes back on. there are no correlations as to when it cuts off or for how long it cuts off. ive heard that is is a simple fix involving soldering something together maybe? a diagram would really be helpful here thanks guys.
![]() Pyps catted x, super 44's dumped, K&N filter, FRPP 4.10's, xcal 3, Maximum Motersports poly IRS bushings W/ 14mm bolts, poly motor mounts, 2003 cobra wheels and headlights |
1999 COBRA
does anyone know what i am talking about?
1999 Mustang GT Convert
I haven't had it happen to mine at least not yet.
Marty |
MasterDeBater
Never Seen that prob with: 97 F-150 2003 Mustang GT 2006 F-150 97 Contour 2001 Escort
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal |
1999 GT Black Coupe
Mine has done that in the past. Usually re-appears minutes later.
#33243 5 Speed w/ Trac-control |
2006 Mustang GT
The cluster has a bad diode in it and the only way to fix it is to replace the cluster.
Richard
![]() 2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII |
2001 YUGO GT
Pull out the gauge cluster from the dash, split the gauge package on the circut board you will find your od chip pull it and user some terminal cleaner (Radio Shack) re-insert. Or just get a new one
1999 COBRA
so i can either clean the one i have or just get a new gauge cluster?
amateur adult film star
it is hapening to mine also i think its common its not a big deal though
![]() ![]() performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
2006 Mustang GT
Here you go try this fix before repalcing cluster.
Intermittent Odometer - A Repair - F150online Forums
Threads Similar to: Search Is No Help For My Question
| parts search | ryanau99 | Parts | 2 | December 4th, 2007 02:50 PM |
| Use Search Function Before Posting Question | White99stang | Drag | 18 | October 28th, 2007 03:36 PM |
| rim search | Kenzo | V6 Mustangs | 18 | September 10th, 2007 07:21 PM |
| SEARCH!!! | mustang1072 | The Clubhouse | 26 | August 31st, 2007 09:59 AM |
