Nitrous (To Do Or Not To Do?)
Old December 18th, 2007, 08:22 PM   #1
Darkside_03_GT's Avatar
2003 GT
Darkside_03_GT is on a distinguished road
Send a message via AIM to Darkside_03_GT
that is the question.
Old December 18th, 2007, 08:31 PM   #2
2004 GT
slow....
pa.ulB is on a distinguished road
Send a message via AIM to pa.ulB
its all preferences, i would say get a wet nitrous kit, but the dry is fine too, window switch, and a purge kit. If you already have one do not go over a 75 without a tune, and thats about it. The install if easy and there no tricks to it.
2004 Crimson red GT
saleen s/c, full bolt ons
Old December 18th, 2007, 08:32 PM   #3
Drgnracin72's Avatar
do, its a kick in the pants
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old December 18th, 2007, 08:38 PM   #4
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
DO IT! It's the best bang for the buck by far.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old December 18th, 2007, 08:44 PM   #5
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
I am as soon as the bolt ons are all finished up...no sense in spending thousands and still get beat on the track.
Old December 19th, 2007, 01:04 AM   #6
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Works wonders for me on a stock mach with a mid pipe. 100rwhp shot should drop about a second off your 1/4 times. Get a pressure heater to help keep pressure in the kill zone.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 19th, 2007, 01:07 AM   #7
workinprogress's Avatar
workinprogress is on a distinguished road
how long will a a car with my mods, and stock internals stand up to a 75 shot of nitrous?
2000 GT, 5spd, K&N drop in, king cobra kit, full dyno tune, pypes o/r x and violator, MGW, termi front clip
Originally Posted by DanTheMan View Post
well what about a pypes violator? would that be too much?
Originally Posted by drgnracin72 View Post
yes, its called the violater for a reason
http://www.youtube.com/mrgearhead87
Old December 19th, 2007, 01:09 AM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
with the right plugs and maybe drop a degree of timming I don't beileve you will see a longevity problem. It will last as long with our without it as long as you don't spray too early or too late. and always run 91 or above.
Military Crew
U.S. Army Aviation
Old December 19th, 2007, 01:10 AM   #9
I always run 93, its tuned for it, and what can prevent iltimed sprays
Old December 19th, 2007, 01:11 AM   #10
and what kind of 1/4 mile et drop can i expect?
Old December 19th, 2007, 01:16 AM   #11
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Window switch will prevent spraying in any rpm but the ones you pick. I recommend the MSD Digital RPM Window switch. It is easy to setup and change on the fly and you don't have to buy those annoying pills and keep a zipper bag full of them just so you can dial in your N20 rpm.
If you find out what jets give you a 100rwhp shot, you should drop around a second give or take. It is VERY important that you understand your programmer and your tune before you use the nitrous. If you have a good 91 octane N/A tune in your car you are running way too much timming for spray. You need to be at about 1-2 degrees retarded off the factory setpoint. I can't stress that part enough. NOT 1-2 off your current tune, 1-2 off factory.
Military Crew
U.S. Army Aviation
Old December 19th, 2007, 01:19 AM   #12
ok thanks, its a future mod but it will be done
Old December 19th, 2007, 01:21 AM   #13
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Did you get a hadheld unit with your dyno tune? Like sct or diablo? If so just go back to the same place and have them make you a nitrous tune and keep it saved in the handheld for when you need it.
Military Crew
U.S. Army Aviation
Old December 19th, 2007, 01:35 AM   #14
will do
Old December 19th, 2007, 06:43 AM   #15
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
these cars can take a 100 w/o a tune, but is highly recommended to have one. 75 is nothing to worry about at all. i have ran literally hundreds of pounds of nitrous thru my car without problems. i spray 125, as long as all supporting mods are done you have nothing to worry about. and a side note, anything over 100 a better fuel pump will be needed.
Threads Similar to: Nitrous (To Do Or Not To Do?)
I Need to know all about Nitrous Damaso 96-98 12 August 28th, 2007 12:04 AM
Is this everything I need for my nitrous kit? flattusmaximus78 General Tech 4 May 21st, 2007 08:56 AM
nitrous 9stang1 5.0 Mustangs 29 January 22nd, 2007 09:48 AM
Nitrous. Texan_Stud V6 Mustangs 33 January 16th, 2007 06:22 PM
