Heads/Cams
Old December 19th, 2007, 11:41 PM   #1
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Heads/Cams
I'll try to make this question quick and painless.
How much would cams run me? How much for an install?
How much would heads run? Install?
Is it best to do both at the same time and what kind of results would I see. Remember that it's a 4V.
360HP / 345TQ N/A
Old December 20th, 2007, 12:43 AM   #2
2000 Mustang Gt
13.56 @ 106
2000stangGT is on a distinguished road
heads = at least 1200
cams = 1000
new springs = 400
install = depends where you go= 500-1000
dyno tune = 300 give or take
so around 3500 id say for you
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams
Manley Valves/Springs - Centerforce Dual Friction
BBK LT's - BBK o/r H - Bassani catback
FRPP 4.10s - XCAL2 - BBK UDP's
306rwhp/333rwtq
Old December 20th, 2007, 12:51 AM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Definatly do both at the same time if you can afford it. Send your heads to fox lake and have them do the port and polish work and then they can custom grind you a set of cams to match. There stage 3 P&P is like $2300 add on the cams and you should be around $3500 don't know about the labor but...
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 20th, 2007, 02:51 PM   #4
Gun Whore
04 Whipple Cobra
10.61@129.96
KingChronic will become famous soon enoughKingChronic will become famous soon enough
for heads, and cam, you really should port your intake too, and you can get damn near 400RWHP. very good setup, but costly.
$800 to have nazman port your heads (guy knows his shit)
$950 for crower cams
$520 for crower springs/retainers
that puts you right at $2300 parts only, and your looking about 1000-1500 to have them installed.
add $300 if you want you intake ported too.
Modded Mustangs Make-A-Wish for Bubba "BWAL09"
[url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url]
[QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE]
Threads Similar to: Heads/Cams
Heads/Cams MATT02GT 99-04 15 October 5th, 2007 06:12 PM
New cams and heads GT/CS 2005 - 2010 2 August 16th, 2007 12:25 AM
Getting Cams and heads DrHolliday 99-04 4 July 2nd, 2007 08:28 PM
CAMS vs Heads nHuman 96-98 10 February 28th, 2007 09:43 AM
PI Cams On Non PI Heads reeds98gt 96-98 13 April 25th, 2006 09:15 PM
