Transmission From A 04 GTO (6 Speed)
Old December 21st, 2007, 04:45 PM   #1
af00stang's Avatar
13.6@100.38mph,(before tune)@3300ft elevation
af00stang is on a distinguished road
will a trans from 04 GTO fit into my 2000 gt.i know a t56 can be put in with some modifications.just not sure exactly what kinda trans a goat has or if it is able to fit.
Old December 21st, 2007, 05:54 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
Tremec T56 Install - StangNet - The Mustang Network
Old December 22nd, 2007, 01:07 PM   #3
af00stang's Avatar
even though the gto has a hydraulic clutch.and the stang doesnt.
Old December 22nd, 2007, 01:14 PM   #4
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
It's not going to be a direct replacement. I belive the input shaft and a few other things are different. I would think the t-56 out of the Cobras will be more suited to bolt-up to your motor.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old December 22nd, 2007, 03:57 PM   #5
af00stang's Avatar
i know it wont be a direct replacement.i was just not sure if the gto trans was a reg t56 or if it was dif for some reason
Old January 15th, 2008, 06:34 PM   #6
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
the input shaft is different
the bellhousing wont work
the gear ratios are different
but if you cna get it for cheep than go for it
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Threads Similar to: Transmission From A 04 GTO (6 Speed)
top speed SLNGT2007 2005 - 2010 16 July 21st, 2008 09:33 AM
top speed emgjsdk1 V6 Mustangs 10 August 26th, 2007 02:32 AM
I need some speed.... Mrdestboi 2005 - 2010 13 August 17th, 2007 05:41 PM
top speed? 00GT 5.0 Mustangs 2 May 17th, 2007 07:42 PM
Question about converting five speed transmission to automat bob 5.0 Mustangs 20 February 22nd, 2007 12:23 PM
