2000 MUSTANG GT
higher octane?
hey guys i have a question regarding the type of gas that i use. a friend of mine said that since i have an sct tune that i should be using a higher octane! is that true, would it really make a diffrence?
Cigar Assassin
depends upon what they tuned it for. did they bump the timing at all in the tune??
if they did, you could get detonation and that is bad for the engine. nasty things could happen
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
2000 MUSTANG GT
i'm going to have to find out, i've had it for a month like that now.
03 gt, 95 740i, 96 disco
![]() ![]() iTrader: 2 reviews
i'd just use a higher octane just to be safe, all i ever run in any car i have is 91(top in ca) because overall its better for the engine.
2000 MUSTANG GT
yeah, i think i'll do that! thanks guys
1988 Mustang LX Turbo
there's no need for a higher octane fuel unless your running boost or nitrous, etc... or if your timing is really advanced
i run 15* timing advance at 28psi on 108 octane
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
amateur adult film star
well mid grade is good for stock low grade os never good for a mustang or any car for that matter high test is what i would run if you have anything done but you dont need 108 aka race gas till you get a high psi sc or some nitrous i also reomend buying a octane booster 1ce a month i use nitro power you can buy it at pepboys it claims 25 hp added instantly i dont beleve it but you do feel something
![]() ![]() performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
2003 SVT Cobra
What octane are you running right now? In any kind of performance v-8 I wouldn't use anything less than 91-93 (whatever is available in your area)
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
theres no need for it, but it is better for your engine. take any sort of engine class and you'll know this. octane is the resistance to burn, and you want the strongest, most acurate ignition on each stroke you can get(hence why its run when timing is advanced), low grade fuel will ignite easier and provides a weaker, less accurate ignition through the lower ignition point of the fuel. i'm not gonna go into great detail here as i'm very tired right now, but that should help someone understand.
what the hell are you saying??????????
I need to run high octane. if i run pump gas all im gonna be doing is having crazy detonation..... and the only way to fix that is to turn down the timing and boost and that will never happen higher octane makes the pistons go up and down the bores straighter when under high pressure
99 limited edition vert
low otane= faster burn
high octane= slower burn Detonation= fast uncontrolled burn(multiple flame fronts colliding)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#12 | |
Preignition (detonation) can occur from higher combustion temperature that can be attributed to lower octane fuels.
#13 | |
lol dam ppl just run whatever the hell you can afford,i get it for free so i run 93 if i had to pay i would buy 87 89 or 91,big dam deal as long as u dont run out of gas
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
i did a 93 octane tune shut off the rear o2s and shut ff the egr and a few other things ,. i have always ran 93 but the tune oke it up big time.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
Threads Similar to: higher octane?
| higher compression pistons | mmvi | V6 Mustangs | 17 | August 11th, 2007 09:13 AM |
| 93 octane? | petrol_head | 5.0 Mustangs | 9 | July 16th, 2007 08:12 PM |
| Higher miles | Juggalo_X | V6 Mustangs | 25 | June 11th, 2007 09:21 AM |
| Car is messing up at higher rpms, every so often | GStam66 | 99-04 | 33 | May 16th, 2007 03:18 AM |
| Gas octane | ByPopularDemand | V6 Mustangs | 11 | May 6th, 2007 08:30 PM |
