Discussing will reving my engine hurt it? in the 99-04 Forum. will reving my engine (after its warm) hurt anything? not redline but to about 4000... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
will reving my engine hurt it?not redline but to about 4000
2002 GT
I Touch Myself Sometimes
1991 GT
19.83 @ 12mph
nope
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
1990 Mustang LX Turbo
8.67@165.91 mph
should be fine, going over 6000rpms is gonna start to do minimal damage and eventually add up
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info Myspace |
Thanks You Sir!
point proven lol
2002 GT
damn wifes uncle said i was going to "hurt my engine" if i keep reving it, what a retard.
i hate people...
2002 GT
8.67@165.91 mph
eventully it will if you do it constant
03 Mach 1--~--1 of 2513
8.9 1/8 mile time
an occasional rev never hurt anyone. but going around like a ricer revving at every thing with 4 wheels might start adding up!
![]() -Josh- 2003 Torch Red Mach 1 Originally Posted by HMUSN it's like racing a mach 1 .. not untouchable but still gonna lose plain and simple no matter how you roll the dice. |
88 Gt
not slow
1992 mustang lx notch
i agree with hun chevs
last time i checked technically every time you hit the gas its reving the engine but i can be wrong
www.myspace.com/lifeisasboringasdeath |
04 Whipple Cobra
Fuckin Fast
any time you free rev a engine with no load on it, is not good for it. but a slight rev every now and then shouldnt hurt anything. if your boosted though i wouldnt rev it hard enough to build boost while free revving.
04 Torch Red Cobra #456 of 3768 born on 11/21/03 |
2003 Mach 1
I would think "free" reving it within a decent rev range (i.e under 5k)would be less hard on the engine than reving it loaded. Its over loading motors than wear them out not under loading.
Under Construction Project N/A 4V Under Way Rep is always welcome |
2001 Mustang Gt
ive never heard of reving hurting anything unless you start going crazy with it. which most people dont do
Garage: http://www.moddedmustangs.com/forums...e-member-9480/ |
#14 | |
lol
2002 GT
#15 | |
1991 Civic DX
16min@42mph
saw a 97ish civic like that, smokin like crazy and complete with a 3 foot spoiler (good for 65hp of course)
My CarDomain My MM Garage 2002 Mustang GT - 4.6 V8, Exhaust & CAI 1991 Civic DX hatch - D15B2, Header ![]() Want my Mustang? <- Click |
2000 mustang GT
11.79@125
i rev mine to 7000 pretty often for about 1 second and then drop the hammer
#17 | |
1991 Civic DX
16min@42mph
#18 | |
2003 Mustang GT
no damage comes from reving an engine unless you go past the redline of the engine, either in gear or not. the only thing it will do is suck down your fuel quicker.
Done occasionally as described by the OP (up to 4k) won't hurt anything but serves no purpose useless you are diagnosing some issue...
Done frequently to the point of becoming a habit, at stop lights, etc. (and also to 4k or so), probably won't hurt anything but it still serves no purpose and will make you look like an @$$-hole... The urban legend persists because in the old days, on carbureted high performance engines, "revving" the engine would cause the accelerator pump (pumps on a dual pumper or multi-carb setup) to squirt gobs of raw fuel into the manifold. So much that it could/would wash the oil off the cylinder walls and cause scoring/galling/etc and contaminate the oil... Gasoline is great stuff as a fuel but it's a piss-poor lubricant. Revving an engine with no load increases the compression load on the connecting rod and crank at BDC because the downward motion has not been resisted by any load on the crank. However the greatest rod load remains a tension load at TDC on the exhaust stroke when the piston and rod want to fly out of the cylinder bore and there is little to no resistance to this because the exhaust valve is still open and the mass/velocity of the exiting gasses are actually pulling it upward. |
#20 | |
1991 Civic DX
16min@42mph
Threads Similar to: will reving my engine hurt it?
| engine reved up and kept reving | ronneone | 5.0 Mustangs | 10 | December 23rd, 2007 12:05 PM |
| do you think this will hurt my car? | afmustanglover | 99-04 | 14 | December 23rd, 2007 09:13 AM |
| 5.0 Over reving on startup | cptkng79 | 5.0 Mustangs | 1 | June 21st, 2007 08:59 PM |
| automatic shifting and reving ? | Redline | V6 Mustangs | 36 | February 15th, 2007 09:46 PM |
| My car is starting to make a high pitched noise while reving | Compy386 | V6 Mustangs | 8 | January 27th, 2007 04:19 PM |
