Discussing Aluminum 4.6 in the 99-04 Forum. i have a 02 gt. i just got a aluminum 4.6 out of a ...
Old December 24th, 2007, 07:43 PM   #1
Aluminum 4.6
i have a 02 gt. i just got a aluminum 4.6 out of a mark VIII. will it work in my gt? what do i need to look for? also how can i tell if it a w or r block? i plan to use bottom end only.
Old December 24th, 2007, 09:59 PM   #2
00vabchgt's Avatar
what year Mark VIII is it? the 93- 98 Mark VIII's had the same aluminum block as the 96- 98 Cobra's...
the block should work fine if you plan on building it for your Mustang.
Submariners Do It Deeper
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Old December 24th, 2007, 11:47 PM   #3
All aluminum blocks from the lincolns were windsor castings, 93-95 also had less bolts on the front and rear main caps. You will also need a timing cover from a 93-95 T bird, one of the bolts on the block will not align properly. A few guys just leave it out or even shallow tap the block to get the bolt in. You wil find that they have 9.8cc dished pistons which will raise the compression quite a bit when used with 2 valve heads. You will also have to drill a water bypass hose on the deck of the block. Locating the hole with a headgasket, then drill away.
Old December 25th, 2007, 05:49 PM   #4
i'm not really sure what year it is i pretty sure it like a 97 or 98. i plan to pull it apart tomorrow and see what i got. if its the same as a cobra engine what would it have in it. is the coponents forged?
Old December 25th, 2007, 06:10 PM   #5
00vabchgt's Avatar
the block was the same as the 96-98 Cobra's, not the internals. i'm pretty sure they're not forged...
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Threads Similar to: Aluminum 4.6
Aluminum 4.6 autogt4.6 Engine 4 December 27th, 2007 12:05 PM
Aluminum DS 07stanggt 2005+ 7 December 11th, 2007 07:36 PM
4.6 aluminum block energiesource 99-04 6 August 3rd, 2007 10:25 PM
Aluminum D/S Racinjason81 V6 Mustangs 5 April 4th, 2007 11:12 AM
Aluminum Driveshaft PONYBOY14 Drivetrain 2 February 3rd, 2007 12:30 PM
