Big Brake Kit or New Rotors
My car has 80,000 miles and the original Rotors. I was wondering if it is really worth the $900 to $1500. to convert to larger rotors OR just buy stock sized drilled and slotted rotors?
Won't I get some braking improvement with drilled and slotted over solid surface rotors? If stock sized drilled and slotted are OK, what is best brand? |
48.47@ 12.58
Welcome to the forums.
Bigger brakes will always stop better than just drilled and slotted rotors. they are worth the upgrade. the question is... Do you feel you really need them with your mods?
#3 | |
reaction time is probably a little slow, but I have been noticing that the brakes fade quite a bit in city driving. Stopping fast more important to me than going fast. |
Gun Whore
04 Whipple Cobra
10.61@129.96
drilled and slotted rotors DO NOT stop better, they cool better, and evacuate brake dust buildup. but you pay for that by losing brake pad surface area.
alot of auto X guys actually recommend OEM rotors, and a good pad. if $$ is tight, get the plain jane brembo rotors, theyre like 40-60 each, and hawk HPS pads. also, get stainless lines in the front, rear isnt as important, but those front you will notice a difference. you can also upgrade to cobra brakes fairly cheap, but for a little more than get the cobra R front brake kit. you may run into clearance problems with big brake kits, and may require larger wheels.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
Gun Whore
04 Whipple Cobra
10.61@129.96
brake fade... you need stainless lines. good pads help too. rotors do not however.
#6 | |
Sorry for the thousand questions.
K&N Cold Air Kit PYPES X PIPE with High Flow Cats Trick Flow Plenum Accufab 70 MM Throttle Body Chrome Strut Tower Brace MRT Hood Strut Polished Alum Radiator Cover J&M Lower Control Arms 275/45/17 Wheel -Tires Diablo Predator (stock tune) |
You can install the Cobra upgrade front & rear, and the assorted other associated goodies for around $1100 The Cobra upgrade including cross drilled and slotted rotors, calipers, steel braided brake lines, Hawk Pads, etc. Front & rear. You could easily perform this install project on a weekend. It's a direct bolt on with no fabbing. With your street driving, I doubt you would feel any brake fading. There are bigger and better brake upgrades out there, but for the money, this package is hard to beat.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. Last edited by gsjohnson; December 27th, 2007 at 09:44 PM. |
#8 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
i have found brembo everything to be a little bit higher quality until you get into the big big bucks, like stop tech and a few other brands. if you dont have much $$$ to spend, just get OEM brembo rotors, no slot, no drill, drilled rotors if not high quality can, and will crack. if you have the $$ though by all means buy a big brake kit. but there is many other things i would spend my $$ on. i think you would be very happy with a good set of pads, and stainless lines with a complete brake flush. and of course the brembo OEM rotors. also, NEVER EVER resurface rotors, especially when warped, when they are resurfaced, they are thinner, and more prone to warp, especially under harsher driving conditions. if rotors are worn, replace them. with high performance pads though they wear faster, so alot of times you can go through 2 sets of pads on 1 set of rotors.
#9 | |
#10 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
BTW, lethalperformance.com, and also tirerack.com both carry everything you need. brembo OEM non slotted non drilled rotors HAWK HPS pads stainless front lines and go to the ford dealer, get yourself motorcraft brake fluid, and fluch the whole system
I road raced professionally for years. Most road racers will prefer synthetic brake fluid because it absorbs less moisture and has a higher boiling temperature than conventional brake fluid. The reason conventional brake fluid turns black is because of obsorbing moisture. Thus the reason for bleeding & flushing of the brake fluid. Will it make you car stop better...Probably not. But in an endurance race such as the 24 hours of Daytona, you better pray that you are using synthetic brake fluid.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
By the way, the Cobra upgrade will clear your Mach wheels.
#13 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
the cobra brake will, but there is a chance the brembo cobra R will not.
Thanks... good to know! But I think I will shop first for stock sizes, then compare against big brake kit. The money I save, could be used for other upgrades I plan like a light bar or speed sensitive stereo.
12.73@111.36
The 13" Cobra front brake upgrade kit works with stock GT rear brakes. Since my front rotors and calipers were shot I upgraded the front brakes and just put high performance rotors and pads on the back.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
i would like some opinions on this.
new front and rear rotors 400 new pads 200 is about 600 to redo my stock stuff right? and i could get a mach1 upgrade front and rear for 400 more. is it worth it?
FX4 Crew
Crew member #3 |
#18 | |
2003 GT
BTW if you are planning on putting a light bar under your car or speed sensitive stereo then you should go ahead and buy the big brake kit. That will just add to the bling! John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles |
if i put better brakes on my car the life of them will increase if my driving stays the same right. ive always just been one to upgrade when something goes out.
FX4 Crew
Crew member #3 |
Threads Similar to: Big Brake Kit or New Rotors
| brake rotors | Badasstang281 | 99-04 | 4 | December 23rd, 2007 10:56 PM |
| brake rotors/wheel size | Bhblondguy | 2005 - 2010 | 5 | October 11th, 2007 01:58 PM |
| Best brake rotors | neckbonekat | 99-04 | 4 | August 28th, 2007 03:31 PM |
| Brake rotors | Stangzilla | 5.0 Mustangs | 5 | May 8th, 2007 09:59 PM |
| brake rotors?? | burnout5.0 | 99-04 | 3 | April 13th, 2007 11:12 PM |
