Running Rich
Old December 28th, 2007, 08:14 PM   #1
94 Mustang GT
kreil45 is on a distinguished road
Running Rich
freind has an 03 cobra goes back and forth from lean to rich. replaced the o2 sensors closes to the engine. still does it. he has a dino tuned wide band gauge that measures it. any thoughts?
Old December 28th, 2007, 09:24 PM   #2
Trick Tuners's Avatar
KB'd GT
Please describe the problem a little better. At idle, at wot?? From what to what?
Old December 28th, 2007, 09:52 PM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Does he have the wide band sensor as well or just the gauge?
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 31st, 2007, 10:05 AM   #4
94 Mustang GT
yes he has a wide band sensor and it does it constantly
Old December 31st, 2007, 02:42 PM   #5
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Has the WB sensor and controller/gauge been calibrated?
Is the heater connected and working?
If changing the front narrowband sensors made no difference or very little difference then I'd suspect the accuracy of the WB system next...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Threads Similar to: Running Rich
running really rich 90pro5.0 5.0 Mustangs 4 October 5th, 2007 06:30 PM
running rich DanishStallion 99-04 6 May 30th, 2007 11:17 PM
Running Rich? SteedaGT02 99-04 7 April 23rd, 2007 08:03 PM
87 GT running way too rich? SDHW44 5.0 Mustangs 4 April 19th, 2007 09:08 PM
Running Rich 87Stang 5.0 Mustangs 14 March 7th, 2007 10:51 PM
