gas with ethanol
Old December 28th, 2007, 10:44 PM   #1
Badasstang281's Avatar
Badasstang281 is on a distinguished road
Send a message via MSN to Badasstang281
gas with ethanol
I just got gas “at Costco aka Giant “and it had a sticker that sad “enchants with ethanol” that is good for my car right???
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs
Old December 28th, 2007, 11:56 PM   #2
Gun Whore
04 Whipple Cobra
10.61@129.96
KingChronic will become famous soon enoughKingChronic will become famous soon enough
all pump gas now has ethanol in it. ethanol is actually great stuff, if you have a place around your area that sells E85 ethanol its actually awesome, its above 100 actane, but the only problem is you have to use alot more of it than you do gasoline, which requires pumps, injectors, and tune.
Modded Mustangs Make-A-Wish for Bubba "BWAL09"
[url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url]
[QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE]
Old December 28th, 2007, 11:58 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
it is good, its all done in percentages. the ethanol will actually fight any water that might get into the fuel system. using to much is hard on the fuel system and is why it is limited to how much can be ran.
Old December 29th, 2007, 12:13 AM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Not to mention it will dry out your seals, Thats why the brand new ones have a tag on the back that says e85 ready. They use different seals in those motors. Alcohol dries out seals and that is the problems you will have with it.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 29th, 2007, 11:34 AM   #5
finaly03vert's Avatar
03 gt vert
lights cant time it
finaly03vert is on a distinguished road
the only problem with ethanol is it is sugar sugar doesn't burn and forms carbon deposit in your motor as well as it leaves residue on intakes if you have a fuel system that precedes it. the only thing you have to do to solve this is " clean out your fuel system and air induction system" i have pulled so many cars apart that simple cleanings would have saved them thousands. but that is the only down fall and i recommend cleaning out your motor anyway if you some how find fuel with out ethanol. feel free to pm me for help with cleaning prod
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods
Curently building up 03 mach block w stage 3 port job. look for twins and more n2o
Old December 29th, 2007, 01:51 PM   #6
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Really, that is intresting to me you got a source for that data. I'd love to read more about it
Thnkx W>P>
Old December 29th, 2007, 03:53 PM   #7
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Ethanol was common in Nebraska when I lived there 20 years ago. I wasn't a big fan of ethanol. I don't think I got as good gas mileage with it and it seemed to cause my motorcycle to vapor lock. Will Seafoam sufficiently clean the fuel system?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old December 29th, 2007, 04:11 PM   #8
03 gt vert
lights cant time it
sea foam is not the best. i prefer bg products the only way to affectively clean is with compressed air sprayers while the engine is running. "air induction and then through the schrader valve on the fuel rails". most lube shops have the equipment. if you need the products i can get them through my guy just let me know i can sell them at cost plus shipping. but only in low quantity's, it is not for sale in California ....this shit works but to do it you need a canister most shops have one so if you have a mech friend ... feel free to pm me if needed
Old December 29th, 2007, 07:01 PM   #9
WAR-PARTY's Avatar
2001 YUGO GT
God as much ethanol as I drink am I gonna need sea foam. But my ethanol comes from Canada LOL
Old December 29th, 2007, 08:44 PM   #10
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
With all the "sugar" in it you will be a damn diabetic by new years then.
Military Crew
U.S. Army Aviation
Old December 29th, 2007, 10:42 PM   #11
amateur adult film star
sgrcltpunk's Avatar
1999 gt
to infinity and beyond
sgrcltpunk will become famous soon enough
Send a message via AIM to sgrcltpunk
well all you have to do is about once a year go get a fuel system cleaning at a shop most shops around here use gum out its about $100 for a 3 step
or you can go to wall mart and they have a 2 step for $20 and the differnce is with the 3 stage they actually swab out the tb with 2 stage is combustion and fuel system cleaning
performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
Threads Similar to: gas with ethanol
Ethanol The eaglenator Racer's Corner 14 November 15th, 2006 08:05 PM
