2001 mustang bullitt
question on autometer gauges.
hey guys
was about to install my boost and fuel gauge and had a couple of questions if anyone knows. my fuel gauge which is a part number 4363 just wondering where would i tap into for the sending unit? on my boost gauge where would i tap into for the line coming from the gauge,i know i tee it some where i just don't know where.
2001 bullittmmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds. Last edited by dcrow; December 29th, 2007 at 09:00 PM. |
Proud American
Fuel pressure would be on the fuel rails.
Boost I have no clue.
2001 GT
![]() iTrader: 1 reviews
Boost can be tapped into the big vacuum line on the back of the intake. just need a T.
The fuel gauge sender will have to be tapped into the fuel rail/line. The line from the tank is on the passenger side at the firewall. You should see it from there and be able to figure out how you're going to plumb it.
The Boost gauge vacuum T has to be tapped into the red plastic vacuum lines at the base of the upper plenum. Hope this helps.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
The Mean Green
The fuel guage gets tapped into the fuel rail where the schrader valve is ( looks like a valve stem almost) you may have to buy an adaptor. All you need for the boost guage is a plastic T connector and splice that into a vacuum line.
Threads Similar to: question on autometer gauges.
| Auto-Meter Nexus Gauges Question. | Hennessey-ShelbyGT500 | Modular Mustangs | 0 | September 19th, 2006 09:38 AM |
| autometer gauge | cali 5.0 | Audio/Video | 1 | August 20th, 2006 02:46 PM |
