2002 GT
99.99@999.9
blowout
sparkplug blow out.... any experianced members with some input would be great
get some new plugs and a new boot ,,inspect the threads in the plug hole for damage if none then ya good to go,, this is a known ploblem with the 4.6
but i have never had this happen to me...good luck
2002 GT
99.99@999.9
the sparkplug has a pretty good bit of damage on the threads. im going to try and find a scope to get a good look at the threads. and some rubber from the boot fell in to the chamber so im probly going to end up being forced to take the head off, but thats something thats going to be a pain in the arse
this is guna sound funny but , you may be able to vacume it out ,,get avacume and some small hose tape the small hose to the vacume hose and then stick the small hose down into the chamber and wiggle it around a in all directions , maybe it will clean out the stuff that fell into the hole...
2002 GT
99.99@999.9
yea thats what some other guys were saying... i let you guys know what happens
What kind of heads? Looks like the threads are no longer in the head. You will probably have to pull the head and helicoil it.
2002 GT
99.99@999.9
sorry its a 02 gt. SOHC. im pretty shure you right the head will be coming off. if the threads on the head look any thing like the plug.. im screwed
You aren't screwed. Its an easy fix. Helicoil kits are your friend.
2002 GT
99.99@999.9
mabey the wifey will let me get some better heads.... muhwahahahah. i love her ignorance with cars...
Resident Bubblehead
i had the same thing happen right after i got my car. thankfully, it still had the extended warranty from ford, so they paid for it all. i ended up getting a new head...
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
its happened to mee too. get a helicoil kit for it, and take your time. i fixed mine in car, just go slow and you will be ok. if you dont think this is something you can do, go to a machine shop or a good mechanic that is comfortable doing it in the car.
KB'd GT
Wow! How did it happen? Is it on a stock motor? Was there any PTV contact or detonation?
2002 GT
99.99@999.9
yes i heard on the 2v 4.6's its a prob. it started off sounding like a belt. so i replaced the belt and pullies. well it would only do it when it warmed up so i traced it to the coil and it would stop if i moved the coil around. took it off and retourqed the plug. going down the road it sounded like a really bad exhaust leak. took the coil off and it was shreaded and the spark plug was beat and craped out.... so if you have a 2v 4.6... CHEAK YOUR PLUGS. and i dont feel skilled enoungh to acctually fix the threads. i can get the head off but the machine shop boys will be getting a visit. ill do a big pic show when im done, but its 4 DEG here to day and i dont have a garage(stupid army housing) so it will be this weekend
