low oil level ?
ok, I just got an 04 gt and aparently who ever changed the oil last only put 5 quarts insted of 6 in the car, i didn't notice anything out of the ordinary just happened to check it and realized this, atleast the 5 that were there are good and clear car has 50,000 miles. My question to some of you ford guys is did this hurt the motor in any way? or would it have to be lower than that. i plan on changing it today for some mobil 1. Brandon
1999 Mustang GT Convert
I doubt there was any damage. I would just check it often for awhile to make sure it's not using oil. Other than that normal cautions such as watching the temp and listening for different noises etc. and you should be fine.
Marty |
You'll be OK, as long as the car wasn't thrashed around (and I mean REALLY thrashed) continually with only 5 qts...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
Thank's guys your making me feel alot better! was really upset about this at first, can see were someone could easily do this that didn't know better!
The manual says 5 qts and ive only ever put 5 in and it shows high on the dipstick, I must of got the smaller engine
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
#6 | |
My '03 actually reads a tiny bit low on the dipstick (3/32" or so) with 6 qts.
well guys just changed it, and you are correct cliffyk mine now reads just a tad low with the new 6 quarts. Sure hope its o.k. does this mean since they had 5 before my crank an pickup was still getting enough oil ? Thank's Brandon
You'll be fine.
You described the oil that was in there a clean, sounds like it might have been changed just before you bought the car and whoever did it "assumed" 5 qts...
#9 | |
Just ongoing improvement, pretty common in the auto industry. They may have been addressing some real issue, or just looking to pump up the time between changes and add a bit of CYA in the process...
faster than the stealth
you'll be fine as long as you keep the oil between the lines. if your oil pressure is normal you should be ok. just make sure you don't overfill it.
1996 Mustang GT 5-speed sold.. ![]() ![]() http://www.youtube.com/watch?v=5VuRDQGk4k8 http://www.cardomain.com/ride/3340297 |
son of a bitch. Alright well i just changed the oil on the 99 stang and i put 6 quarts in her due to that is what i read all over the net not knowing that ford changed the oil pans some time in 01 or whenever. Ill check it tomorrow when i get up because it is about 10deg and windy out. But im worried now because 1 quart over is no small amount. I have prob put a good 600 miles on her since the change. Possible damage done? Im glad i looked at this tread. Dont get why ford has to change everything all the time. Should of just done it right the first time. Please help
Threads Similar to: low oil level ?
| Boost Level for supercharger | mustang_s | General Tech | 8 | October 4th, 2007 05:47 AM |
| time to take it to the next level! | 2007calispecial | 2005 - 2010 | 14 | July 31st, 2007 02:18 PM |
| level car | rayme | 5.0 Mustangs | 6 | April 9th, 2007 12:48 PM |
| level 10 shift kits | 92_fox | 5.0 Mustangs | 8 | December 15th, 2006 06:24 PM |
| Coolant level? | TorqueMonster | V6 Mustangs | 1 | August 23rd, 2006 11:36 PM |
