Rough Idle
Old January 2nd, 2008, 05:18 AM   #1
MineralGreyGT's Avatar
MineralGreyGT will become famous soon enough
Rough Idle
Hey, I recently started to notice after a bit of driving my car idles pretty ruff it tries to stay at 700 rpms but drops every second or so to 500 it almost feels like its going to stall, here is what I have done so far to try and fix it, new coil packs and plugs, carb cleaner for the IAC, cleaned the MAI, I put back the original IAC gasket, took off MAI screen, Unplugged the battery for 5-7mins, but no results the only conclusion I have left is a vacuum leak but I can't seem to find one. any advice is appriciated!
Old January 2nd, 2008, 10:31 AM   #2
02MODGT's Avatar
02MODGT is on a distinguished road
If you can't find the leak then replace the IAC.
Old January 2nd, 2008, 10:37 AM   #3
Trick Tuners's Avatar
KB'd GT
Did you install a new tune, or any aftermarket parts or did the issue just pop up?
Old January 2nd, 2008, 11:01 AM   #4
workinprogress's Avatar
workinprogress is on a distinguished road
start tracking vac lines, there is alot to keep track of around the trottle body on these cars, one may be dry and cracked, or just loose
2000 GT, 5spd, K&N drop in, king cobra kit, full dyno tune, pypes o/r x and violator, MGW, termi front clip
Originally Posted by DanTheMan View Post
well what about a pypes violator? would that be too much?
Originally Posted by drgnracin72 View Post
yes, its called the violater for a reason
http://www.youtube.com/mrgearhead87
Old January 2nd, 2008, 12:57 PM   #5
i installed new tune new tb and plenum like 4 or 5 months ago, just showed up out of nowhere. The IAC looked fine the car only has 59K miles. I'm going to try and back track the vac lines.
Old January 4th, 2008, 07:58 AM   #6
anyone thinks it might be the TPS? if so where can I find the TPS? considering I have a 75mm TB and plenum?
Old January 4th, 2008, 09:11 AM   #7
1967 mustang coupe
ma67cpe is on a distinguished road
Send a message via Yahoo to ma67cpe
When my car had around 60 on it it was doing the same thing. I just replaced the throttle and the tps for about 70 bucks.
It should be a factory TPS. At least it is on my acufab TB
Old January 4th, 2008, 11:13 AM   #8
KB'd GT
Its not the TPS. Do you have a datalogger?
Old January 4th, 2008, 12:32 PM   #9
closest thing i have is the diablo tuner and the only codes im getting are the normal ones when u install a tuner. It sucks that its been really cold lately, I'm going to attack all that tommorow morning.
Old January 4th, 2008, 12:34 PM   #10
KB'd GT
You can datalog with the diablo tuner. Shoot me a datalog with maf counts, rpm, stft, ltft, tp, pressure drop across injectors, and IAC duty cycle.
Old January 4th, 2008, 12:37 PM   #11
alrite, I'll try and get that on here later on tonight when I get home from work, thanks for the help.
Old January 4th, 2008, 08:19 PM   #12
all rite here goes I'm not sure if I got everything but here is what I got
MAF V 0.4v
rpm 0
STFT1 -25%
STFT2 -25% <-- there was no LTFT
FRP 39psi
TP 0.88v
74F IAT
The second time I did it
56F IAT
o RPM
0.4v MAF V
37psi FRP
10deg spark advance
70.9% load
open feed back fuel
92F Eng coolant
STRT1 -22%
STRT2 -22%
TP 0.81v
Thats pretty much the same data I got on the different options I chose I've never used data logging before. The car stays off correct? thats what I did anyway well thanks again for the help.
Old January 4th, 2008, 08:28 PM   #13
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
it could be the TPS, i had a probalem with mine, but i had a code coming up. try cleaning the IAC and check for a vacuum leak...
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old January 4th, 2008, 10:10 PM   #14
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
MAF V 0.4v
rpm 0
STFT1 -25%
FRP 39psi
TP 0.88v
74F IAT
56F IAT
o RPM
0.4v MAF V
37psi FRP
10deg spark advance
70.9% load
open feed back fuel
92F Eng coolant
STRT1 -22%
STRT2 -22%
TP 0.81v
not sure,but think he will want data with rpm and at normal operating temp
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old January 4th, 2008, 10:11 PM   #15
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ +1
go do a 3rd and 4th gear pull while data logging
Old January 4th, 2008, 11:19 PM   #16
KB'd GT
No need for more data. Its either a vacuum leak or a bad tune. Did the tuner customize the tune based on your data? 25% is as far as the computer can correct fueling and its pegged so who knows how bad it really is. You should not go WOT till you get this figured out.
Old January 5th, 2008, 07:30 AM   #17
that is the tune that cam with the programmer, all I did was advance the spark timing I'll try to reinstall the factory tune then reinstall the normal tune. I aslo noticed where the hose clamps on the throttle body is loose I overtightened it and I broke the clamp but it seemed nice and sturdy when I was done I guess from all the removing and installing it got loose. I'm going to get new hose clamps and try to replace the dried out hose connections.
Old January 5th, 2008, 12:06 PM   #18
limited's Avatar
you need to datalog with the car running,both those log's the car is not.
Old January 5th, 2008, 02:20 PM   #19
well I found out that the diablo tune is all f'd up its running really lean even if i reset all the parameters it runs to lean, but it runs fine with the stock tune so I'm going to have to have it dyno tuned, o well atleast I'll know what I'm putting down at the wheels thanks for the help guys much appriciated!
Old January 5th, 2008, 09:51 PM   #20
head ache grows worse now it wont calibrate the speedo towards my 4.10 gears wtf!?!?
Threads Similar to: Rough Idle
Rough Idle killagt46_t-top 99-04 5 April 20th, 2010 11:22 AM
Rough Idle/First Gear Start silvergtstang99 99-04 3 November 28th, 2007 01:28 AM
rough idle :-\ help please! i know nothing about cars. tehdwarvenn 5.0 Mustangs 8 November 5th, 2007 10:01 PM
rough idle, bog @ 3500 RPM Lmagee 5.0 Mustangs 11 September 19th, 2007 01:01 AM
Rough Idle and Almost Dies After Warmed Up Gallie 5.0 Mustangs 10 April 12th, 2007 08:27 PM
