Shift Light Signal Hookup??
Okay guys I just purchased the Auto Meter DPSS Gauge (Digital Tach + Shift Light, etc.) and I do not know where to hook up the signal wire to get the RPM reading. Does anyone know?? It says connect to the negative terminal of a standard ignition coil, or "Tach Output" terminal on the Electronic Ignition Module (Which I don't have). I have a Haynes manual but I couldn't pin point a spot to tap into. Help me out guys!
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!! Now... ...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition.. www.cardomain.com/id/po1snd_u |
I just did one on a jetta, we put it on negative side of ignition coil, hot and ground wire.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
Yeah I know that but 99+ 4.6L have the coil on plug design. All of them have a red wire and a second wire that varies in color from coil to coil. Has anyone done these on a Mustang?
Proud American
U have to get a tach adapter. If it were in a 96-98 i could tell you the wire that goes to the tach in the dash.
Threads Similar to: Shift Light Signal Hookup??
| Shift light!!! | JONJON | 5.0 Mustangs | 7 | October 31st, 2007 09:45 PM |
| brake light/turn signal probel | jim.munoz | V6 Mustangs | 2 | October 20th, 2007 05:18 PM |
| Turn Signal Light | BoomerSixZero | Classic Mustangs | 6 | June 10th, 2007 08:17 AM |
| Turn Signal Light | themav46 | V6 Mustangs | 4 | September 30th, 2006 10:09 AM |
| Mach 1 signal light problem | tony123 | Classic Mustangs | 1 | June 12th, 2006 06:38 PM |
