Tuner
SCT or DIABLO
or any others? i want a tuner, just got a raise.. and income tax is coming up before too long. its mod time.. tuner is on the mind.. suggestions pleaaaaaaaaaase!
![]() Originally Posted by HMUSN it's like racing a mach 1 .. not untouchable but still gonna lose plain and simple no matter how you roll the dice. SaleenWolf720: need horsepower?? no, you just need bald tires, then you'll really feel the power |
48.47@ 12.58
SCT imo
sct, i used the xcal 2
![]() 2000 ford mustang gt convertible 2004 ford lightning truck,,,,,sold 2001 ford mustang/cobra,,,,sold 2008 ford f-350 4x4 truck 1989 ford notch back 5.0 2006 custom build bobber |
¡ʇsnq ɹo uʍop ǝpısdn
Fixt
Find out what your local shops use, that way if you ever get it professionally tuned or dyno'd you have a flash device that there system is compatible with... and if they use Diablo find another tuner
stay away from sniper i agree on the rest of his comment tho
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
N/A 4v Guru
2003 Mach 1
Why? Its a great tuner. Great adjustability and easy to understand end user functions. SCT is good too but I would get the xcal 3. Same stuff as the 2 plus some. Diablo is just fine.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i have a diablo and like it, i recommend it. but it is important to use what your tuner is using. cant go wrong with any of them really. all are reputable, and are recommended.
locals use sct
Cigar Assassin
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
2002 mustang GT
13.2 @104mph
I have an sct 4 bank because thats what my favorate shop (dez racing) uses and since he was burning it I figured it would be best.I don't have much feedback because the shop burned it and I havn't had to touch it at all.
02 GT. 04 Z1000 (hooligan machine) 04 gsxr 600 98 GTP |
2001 Mustang SVT Cobra
Sniper is too new and still have a lot to fix/correct within their own paramaters, still have some weak zones. Same with the Xcal3. Don't be the guinea pig for either one. Either Xcal2 or Diablo.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
#13 | |
I can assure you there are no WEAK ZONES with Snipers Software .......the datalogging still is being worked on for the 05-up GTs but everything else is fine I assure you ... |
Sniper seems to have gotten their act together with version 15.x of the interface firmware (at least it works reliably without locking up, and the data logging works too). I also picked up another 6 HP peak and 5-20 HP in the 3500 to 4800 rpm range using a tweaked version of their 93 octane/X-pipe/catback basic tune (versus a tweaked Granatelli Fuego 93 octane tune).
This said however I would only recommend the Sniper SF package to those who are willing to participate in the evolution of a products that has a lot of promise, some of which is as yet unfulfilled. For example, the Special Forces tuning software has no provision for documenting the selected timing or fuel modifiers. You must do this manually, create and Excel worksheet, or whatever--I.e. reloading a saved tune's ".txt" file provides NO indication of what timing and fuel settings were used to create that tune, so you need to keep a log of tune filenames vs. settings to keep things straight. This is further complicated by an artificial 15-character filename limitation imposed by their "save file" dialog (I suspect driven by filename size limitations of the interface). The Recon software also has great "as yet unrealised" potential, however it suffers from the lack of any persistence of user configuration and a few PID data presentation issues--a new version has been promised "real soon now". Sniper's support is great, they are readily available (M-F, 9-6) and via telephone and in person have always made me feel as though my problem truly was their problem. However when your PCM is trashed on a Friday night due to a firmware error and you find yourself walking for the weekend this is of little consolation--I still will not flash my tune other than M-F 9-6. Another good thing is that the Sniper community is active and supportive, and also quite zealous (I'm certain I will have riled the faithful with what I've said here). I'm going to stick with Sniper's system because there is great potential, however all said and done if I had it to do over again I would have gone with SCT.
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
KB'd GT
+1 I dont think the Xcal3 is really ready yet.
Gun Whore
04 Whipple Cobra
10.61@129.96
SCT > everything else.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
2009 Mustang GT
2009 Mustang GT Bone Stock
Gun Whore
04 Whipple Cobra
10.61@129.96
2009 Mustang GT
I don't know what you are talking about so I am going to have to go with no lol.
![]() EDIT: Ok AR15.com, but still no.
Gun Whore
04 Whipple Cobra
10.61@129.96
snipershide.com, and ar15.com. theres a guy on each of those that posts as medic chris.
Threads Similar to: Tuner
| SCT X3 Tuner Help | SKRAPR | 2005 - 2010 | 9 | January 21st, 2008 11:06 AM |
| sct tuner | d2daj86 | V6 Mustangs | 6 | September 3rd, 2007 04:32 PM |
| need a new tuner !!!! | hookandpull | 5.0 Mustangs | 1 | July 20th, 2007 05:55 PM |
| tuner | gooberhead320 | V6 Mustangs | 58 | July 6th, 2007 11:18 AM |
| what exactly is a tuner? | trebel14 | Modular Mustangs | 18 | February 20th, 2007 11:49 AM |
