Busted passenger side mirror
Old January 3rd, 2008, 03:48 AM   #1
Novanutcase's Avatar
2003 GT
Novanutcase has a spectacular aura aboutNovanutcase has a spectacular aura aboutNovanutcase has a spectacular aura about
Some dumb@ss truck clipped my passenger side mirror and broke it!
I was stuck in traffic and he decided to try and get around everyone by going down the parking lane. Unfortunately, when he hit my mirror I was boxed in so I couldn't chase him since he just sped away!
I found a mirror on E-bay for $44 but before it gets here I wanted to find out how I remove and replace the mirror! Can anyone give me a step by step?
Thanks!
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles
Old January 3rd, 2008, 09:36 AM   #2
ATLmustang is on a distinguished road
if im not mistaken you pop the triangle piece out on the inside of the door and there should be three nuts holding the mirror on and just unclip the power wires. should be that easy
Old January 3rd, 2008, 12:17 PM   #3
02MODGT's Avatar
02MODGT is on a distinguished road
Do the above but you may have to remove the door panel to unhook the electric connector for the power mirror.
Old January 3rd, 2008, 12:22 PM   #4
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
No need to remove the door panel. the electrical connector is fully and easily accessed after the door switch panel has been removed and unplugged.
Old January 3rd, 2008, 12:23 PM   #5
02MODGT's Avatar
Well fuck me.
Old January 3rd, 2008, 12:26 PM   #6
energiesource's Avatar
energiesource is on a distinguished road
i had to do this to my moms car a few weeks ago
pop the speaker cover off, take the 3 bolts off for the mirror, take the handle/switch panel out, unscrew (2) the cover so you can take the handle off, just makes it easier. then unclip the mirror plug inbetween the mirror and the handle opening, and pop the clip out, and repeat the process.
Old January 3rd, 2008, 12:29 PM   #7
Juggalo_X's Avatar
14+@Slow
no need to remove the handle either. the connector is right there. as soon as u remove the button panel.
Old January 3rd, 2008, 12:31 PM   #8
yes but the red clip was a pain and 3/4 for me to get out. i dont have small azn fingers and im assuming alot of you dont, so it makes it easier getting it out from the handle side instead of the top
Old January 3rd, 2008, 12:41 PM   #9
Juggalo_X's Avatar
14+@Slow
if u say so but i got big bear mits here. and i replaced my mirror in december in about 5 min flat the way i described. popped the speaker cover, removed speaker. removed mirror bolts. removed switch panel on door and unplugged it. unplugged mirror electrical connector. fed new mirror wire through hole. installed new mirror and tightened the bolts. plugged in the mirror electrical connector. replaced the switch panel. replaced the speaker.
tested mirror.
done
Threads Similar to: Busted passenger side mirror
Side Mirror Blinkers dStoltenberg 5.0 Mustangs 13 August 17th, 2007 01:55 AM
Side View Mirror gills99stang 99-04 15 May 15th, 2007 12:34 PM
Is there anybody else who can't stand their side view mirror ponyup 2005 - 2010 28 April 1st, 2007 11:12 PM
